Check Re-Calls & Service History Here
Old May 11, 2008 | 10:18 PM
  #451
Onetogofast's Avatar
Originally Posted by Torque_Wrench
Get your Onstar took care of. But you do have a lenghty repair history and I don't like the looks of having your doors adjusted. And you seem to have one dorr that keeps needing adjustment. That's not a good sign. Di you buy this thing used?
VEHICLE INFORMATION
Merchandising Model : CK15753 -2005 SILVERADO 1500 4WD EXT CAB Z71 Warranty Start Date : 12/30/2004
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : WESTGATE CHEVROLET, CADILLAC
7300 I40 W
AMARILLO , TX 79106-1809
(806) 356-5600
Selling Source : 13 - CHEVROLET
Site Code : 07423
Business Associate Code : 112452
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Type Number Description Posted Date Status
SB 06049 ONSTAR H/W IS DIGITAL-CAPABLE. NO UPGRADE IS NEEDED. SEE TSB 06-08-46-008. 02/22/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID NDN4708X XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 12/30/2004 10 miles 12/30/2007 36010 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 12/30/2004 10 miles 12/30/2010 100010 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 12/30/2004 10 miles 12/30/2012 80010 miles
36/36000 FEDERAL EMISSION 12/30/2004 10 miles 12/30/2007 36010 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
10/20/2006 242550 # E9050 - POWER STEERING PUMP REPLACEMENT 39356 miles
08/14/2006 073610 # B4400 - REAR SIDE DOOR UP/DOWN ADJUSTMENT - RIGHT SIDE 35864 miles
08/14/2006 073610 # N6620 - WIRING AND/OR CONNECTOR - POWER & GROUNDS DISTRIBUTION - R 35864 miles
08/14/2006 073610 # D4707 - HVAC CONTROL HEAD MODULE OR ASSEMBLY REPROGRAMMING WITH SP 35864 miles
08/14/2006 073610 # C0182 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - RIGHT SIDE 35864 miles
01/12/2006 068920 # D1212 - SENSOR, INSIDE AIR TEMPERATURE - REPLACE 25468 miles
01/12/2006 068920 # J6355 - POWERTRAIN CONTROL MODULE TRANSMISSION REPROGRAMMING WITH 25468 miles
01/12/2006 068920 # K6360 - SEAL, EXTENSION HOUSING REAR - REPLACE 25468 miles
10/24/2005 067276 # F1440 - OUTPUT SHAFT SEAL REPLACEMENT - RIGHT SIDE 19529 miles
10/24/2005 067276 # C0140 - CHANNEL AND/OR RETAINER, FRONT DOOR WINDOW RUN (FRONT) - R 19529 miles
10/24/2005 067276 # B4400 - REAR SIDE DOOR UP/DOWN ADJUSTMENT - RIGHT SIDE 19529 miles
10/24/2005 067276 # B4401 - REAR SIDE DOOR UP/DOWN ADJUSTMENT - LEFT SIDE 19529 miles
10/24/2005 067276 # C0546 - HINGE, QUARTER GLASS SWING OUT - RIGHT - REPLACE 19529 miles
10/24/2005 067276 # C0547 - HINGE, QUARTER GLASS SWING OUT - LEFT - REPLACE 19529 miles
09/28/2005 066780 # R5126 - ON-STAR VIU/VCIM COMP RET TO AC/DELCO ESC 17153 miles
09/28/2005 066780 # R5140 - MODULE, VEHICLE INTERFACE UNIT VIU/VCIM - REPLACE 17153 miles
10/08/2004 A57892 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Yea, I bought it used with 16000 on it. The doors were rediculous and the driver side still gives me some trouble but not as bad. Thanks for the info, Ill get the onstar checked
Old May 12, 2008 | 12:04 AM
  #452
Parke10's Avatar
This should be the last one i bug you with for awhile 2GTEC19TX31396723 and if you have any way of gettin a build sheet or RPO list that would be awesome , if not whatever you can do will help a ton, thanks again
Old May 12, 2008 | 12:09 AM
  #453
1BADAZZSS's Avatar
Can you tell me what recalls and service history is on my truck. Thanks
vin#1GCEC14T74Z245984
Old May 12, 2008 | 08:58 AM
  #454
A build sheet, RPO list?? Lol....hardly nothing...I got you covered.
You have a bit of a lengthy service history on this unit bro...but no open re-calls.
VEHICLE INFORMATION
Merchandising Model : TC15753 -2003 SIERRA 1500 2WD 4 DOOR PICKUP Warranty Start Date : 06/28/2003
Delivering Dealer : MOTOR CITY BUICK PONTIAC GMC
PO BOX 40340
BAKERSFIELD , CA 93384-0340
(661) 836-9000
Selling Source : 48 - GMC TRUCK
Site Code : 42276
Business Associate Code : 118685
Service Contract : Yes Branded Title : No Warranty Block : No PDI Status : Paid
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
Vehicle Has No Current Record Of Outstanding Service Information
Vehicle Has No Associated On Star or XM Radio Information.
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 06/28/2003 19 miles 06/28/2006 36019 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/28/2003 19 miles 06/28/2009 100019 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/28/2003 19 miles 06/28/2011 80019 miles
36/50000 CALIFORNIA EMISSIONS 06/28/2003 19 miles 06/28/2006 50019 miles
84/70000 CALIFORNIA SELECT COMPONENT 06/28/2003 19 miles 06/28/2010 70019 miles
CLAIM HISTORY
11/30/2006 345571 0 H2505 - ELECTRONIC BRAKE AND TRACTION CONTROL MODULE REPLACEMENT 40993 miles
06/14/2006 105470 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 35571 miles
06/14/2006 105470 # Z7901 - 1-DAY COURTESY TRANSPORTATION 35571 miles
06/14/2006 105470 # E9740 - GEAR ASSEMBLY, POWER STEERING - REPLACE 35571 miles
03/25/2005 268852 # N4180 - INSTRUMENT CLUSTER REPLACEMENT 19870 miles
03/25/2005 268852 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 19870 miles
03/17/2005 267975 # N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 19785 miles
01/18/2005 093474 # E8041 - TIE ROD, INNER - LEFT - REPLACE 18316 miles
01/18/2005 093474 # N2220 - SWITCH - ENGINE OIL PRESSURE SENDER - REPLACE 18316 miles
01/18/2005 093474 # L0620 - EVAPORATIVE EMISSION CANISTER REPLACEMENT 18316 miles
01/18/2005 093474 # Z7903 - 3-DAY COURTESY TRANSPORTATION 18316 miles
01/18/2005 093474 # E8040 - TIE ROD, INNER - RIGHT - REPLACE 18316 miles
01/07/2005 093224 # N4180 - INSTRUMENT CLUSTER REPLACEMENT 17962 miles
06/03/2003 A96723 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
VEHICLE BUILD
Gross Vehicle Weight Rating : 2815 kg (6207 lb) Order Number : GGVP27
Build Date : 06/03/2003 Build Plant : 23153
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AE7 - FULL BENCH LEATHER SEAT WITH LEATHER TRIM AG1 - POWER DRIVER SEAT ADJUSTER
AJ1 - DEEP TINTED GLASS AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT
AM7 - FOLDING REAR SEAT AU0 - REMOTE KEYLESS ENTRY SYSTEM
AU3 - POWER DOOR LOCKS A31 - POWER WINDOWS
B30 - FULL COLOR KEYED CARPET W/MATS B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR-KEYED FLOOR MATS B85 - BLACK BODYSIDE MOLDINGS
CJ3 - AIR COND., DUAL ZONE MANUAL C49 - ELECTRIC REAR WINDOW DEFOGGER
DF5 - ISRV MIRROR W/COMPASS & TEMP DK7 - CUSTOM INTERIOR ROOF CONSOLE
DL8 - HEATED POWER ADJ EXTERIOR MIRRORS EVA - EVAP EMISSION REQUIREMENT
E63 - WIDESIDE BODY GT4 - REAR AXLE - 3.73 RATIO
G80 - LOCKING REAR DIFFERENTIAL JC3 - 4 WHEEL ANTI-LOCK DISC BRAKES
KNP - H.D. TRANSMISSION OIL COOLER KUP - THROTTLE CONTROL ELECTRONIC
K34 - ELECTRONIC SPEED CONTROL K47 - HIGH CAPACITY AIR CLEANER
K68 - ALTERNATOR 105 AMP LM7 - VORTEC 5300 V8 SFI GAS ENGINE
M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL NC8 - CALIFORNIA ULTRA LOW EMISSIONS
NP5 - LEATHER WRAPPED STEERING WHL OSG - ASSEMBLY PLANT, OSHAWA, ONTARIO
QCC - P255/70R16 ALS BW TIRES QC3 - POLISHED ALUMINUM WHEELS
Q4B - GVW RATING - 6200 LB R6J - CUSTOMER DIALOGUE NETWORK
R9U - GM ACCESS-AUTOBOOK IDENTIFIER R9Z - POMS EXPEDITE-SOLD ORDERS
SAF - SPARE TIRE LOCK SLM - STOCK ORDERS
TFE - SALES INCENTIVE-COMMITMENT PLUS T96 - FRONT FOG LAMPS
UB0 - AM/FM STEREO W/CD UK3 - STEERING WHEEL RADIO CONTROLS
UQ3 - ENHANCED PERFORMANCE SPEAKERS VB3 - CHROME REAR BUMPER
VG3 - CHROME FRONT BUMPER VG8 - BUYER NOTICE LABEL
VK3 - FRONT LICENSE PLATE MOUNT VP6 - NOISE CONTROL
VR4 - WEIGHT DIST HITCH PLATFORM VXS - COMPLETE VEHICLE LABEL
V22 - CHROME GRILLE SURROUND V73 - STATEMENT OF CERT. U.S.
V76 - RECOVERY HOOKS XCC - P255/70R16 ALS BW TIRES
YA7 - CALIF. ASSY. LINE EMISSION TEST YCC - P255/70R16 ALS BW TIRES
YD3 - BASE EQUIP FOR SCH GVW PLATE YD6 - REAR SPRING - BASE EQUIPMENT
YE9 - SLE/SLT DECOR YF5 - CALIFORNIA EMISSIONS
ZCC - P255/70R16 ALS BW TIRES ZY1 - SOLID PAINT
Z82 - HEAVY DUTY TRAILERING EQUIPMENT Z85 - HANDLING/TRAILERING SUSPENSION PACKAGE
Z88 - GMC TRUCK NAMEPLATE 1SC - SLE DECOR INCLUDES: AIR COND., DUAL ZONE MANUAL CRUISE CONTROL REMOTE KEYLESS ENTRY W/ALARM POWER WINDOWS & DOOR LOCKS AM/FM STEREO W/CD REAR WINDOW DEFOGGER POWER HEATED OUTSIDE MIRRORS DEEP TINTED GLASS ISRV MIRROR W/COMPASS & TEMP
1SZ - OFF-ROAD PKG DISCOUNT 11U - PEWTER METALLIC
52D - NEUTRAL CUSTOM CLOTH 52I - NEUTRAL INTERIOR TRIM
6MT - COMPONENT FRT LH COMP. SEL SUSP 7MT - COMPONENT FRT RH COMP. SEL SUSP
Old May 12, 2008 | 09:00 AM
  #455
You got nothin'...clean as a pin bro.....
VEHICLE INFORMATION
Merchandising Model : CC15703 -2004 SILVERADO 1500 2WD REG CAB WT Warranty Start Date : 03/20/2004
Delivering Dealer : ADAMS CHEVROLET, INC.
7820 E 171ST ST
BELTON , MO 64012-5325
(816) 331-4300
Site Code : 05279
Business Associate Code : 111845
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 03/20/2004 25 miles 03/20/2007 36025 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/20/2004 25 miles 03/20/2010 100025 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/20/2004 25 miles 03/20/2012 80025 miles
36/36000 FEDERAL EMISSION 03/20/2004 25 miles 03/20/2007 36025 miles
CLAIM HISTORY
04/17/2007 795514 # N1730 - BLOCK ASSEMBLY, WIRING HARNESS JUNCTION - ENGINE - REPLACE 34901 miles
01/23/2004 A45984 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Old May 12, 2008 | 09:49 AM
  #456
dhpro's Avatar
Can u pls check mine?
3GNEK12T64G139040 2004 Avv Z-71
Thnx R/
Old May 13, 2008 | 09:07 AM
  #457
Thnx R/
No problem, here you go friend...
You have a lenghty service history but it's mainle because it seems there was a GM Maintenance plan on this vehicle.
VEHICLE INFORMATION
Merchandising Model : CK15936 -2004 AVALANCHE 1500 4WD Warranty Start Date : 10/03/2003
Delivering Dealer : THE KARL CHEVROLET COMPANY
PO BOX 1146
NEW CANAAN , CT 06840-1146
(203) 966-9508
Site Code : 02289
Business Associate Code : 111148
RC 05037 SECOND ROW CENTER SAFETY BELT N/A Closed
SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. 02/21/2007 See Bulletin
XM Equipped Yes XM Radio ID 03BU204R XM Status Active Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 10/03/2003 0 miles 10/03/2006 36000 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 10/03/2003 0 miles 10/03/2009 100000 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 10/03/2003 0 miles 10/03/2011 80000 miles
36/50000 CALIFORNIA EMISSIONS 10/03/2003 0 miles 10/03/2006 50000 miles
84/70000 CALIFORNIA SELECT COMPONENT 10/03/2003 0 miles 10/03/2010 70000 miles
CLAIM HISTORY
03/13/2008 120254 0 E8040 - TIE ROD, INNER - RIGHT - REPLACE 44919 miles
03/13/2008 120254 # B5795 - BEZEL, TAILGATE/ENDGATE OUTSIDE HANDLE - REPLACE 44919 miles
03/13/2008 120254 0 E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 44919 miles
03/13/2008 120254 0 E8041 - TIE ROD, INNER - LEFT - REPLACE 44919 miles
02/06/2007 149754 0 B5830 - LATCH, TAILGATE/ENDGATE - RIGHT - R&R OR REPLACE 38719 miles
02/06/2007 149754 0 B5831 - LATCH, TAILGATE/ENDGATE - LEFT - R&R OR REPLACE 38719 miles
02/06/2007 149754 0 N4180 - INSTRUMENT CLUSTER REPLACEMENT 38719 miles
01/17/2007 149096 0 B5800 - ENDGATE HANDLE REPLACEMENT 38077 miles
12/22/2006 148396 0 E2321 - BEARING AND HUB ASSEMBLY, FRONT WHEEL - LEFT - REPLACE 37212 miles
12/22/2006 148396 0 B5939 - STRIKER, LIFTGATE/ENDGATE/TAILGATE - ADJUST OR REPLACE 37212 miles
09/22/2006 145573 0 M0017 - LUBE, OIL AND FILTER 34553 miles
09/22/2006 145573 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 34553 miles
05/26/2006 141729 0 M0017 - LUBE, OIL AND FILTER 29069 miles
05/26/2006 141729 # N6644 - WIRING AND/OR CONNECTOR - MIRROR SYSTEM - REPAIR OR REPLAC 29069 miles
05/26/2006 141729 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 29069 miles
01/19/2006 137522 0 M0017 - LUBE, OIL AND FILTER 24363 miles
01/19/2006 137522 # B4150 - OUTSIDE REARVIEW MIRROR GLASS REPLACEMENT - RIGHT SIDE 24363 miles
10/06/2005 133652 0 M0017 - LUBE, OIL AND FILTER 20650 miles
10/06/2005 133652 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 20650 miles
10/06/2005 133652 # V1382 - 05037 - STITCH SEAT LOOP CLOSED 20650 miles
09/04/2005 726010 # Z2080 - ROADSIDE SERVICE (TOWING) 19000 miles
06/14/2005 129406 0 M0017 - LUBE, OIL AND FILTER 17305 miles
01/06/2005 230344 0 M0015 - LUBE, OIL AND FILTER 13581 miles
10/15/2004 120468 0 M0017 - LUBE, OIL AND FILTER 11785 miles
10/15/2004 120468 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 11785 miles
10/15/2004 120468 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 11785 miles
08/06/2004 222093 0 M0015 - LUBE, OIL AND FILTER 7850 miles
08/06/2004 222093 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 7850 miles
05/10/2004 114362 0 M0017 - LUBE, OIL AND FILTER 4560 miles
05/10/2004 114362 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 4560 miles
01/12/2004 109953 0 M0017 - LUBE, OIL AND FILTER 1413 miles
01/12/2004 109953 # B1784 - ARM, WIPER - WINDSHIELD (ONE OR BOTH) - REPLACE 1413 miles
10/16/2003 106754 # Z6999 - PDI RELATED FLUID ADDS 8 miles
09/25/2003 A39040 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Old May 15, 2008 | 06:25 PM
  #458
Zitty'sZ's Avatar
Can you please checkout my truck ? Vin # 2GCEC19V011305148 , thanks .
Old May 16, 2008 | 11:50 AM
  #459
Here ya go pal....
VEHICLE INFORMATION
Merchandising Model : CC15753 -2001 SILVERADO LS 1500 2WD EXT CAB Warranty Start Date : 02/23/2001
BARS Order Type : 50 - FLEET
Delivering Dealer : ED MORSE CHEVROLET
6363 NW 6TH WAY, STE 410
FORT LAUDERDALE , FL 33309-6188
(954) 733-6000
Site Code : 26345
Business Associate Code : 114783
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 02/23/2001 10 miles 02/23/2004 36010 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 02/23/2001 10 miles 02/23/2007 100010 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 02/23/2001 10 miles 02/23/2009 80010 miles
36/36000 FEDERAL EMISSION 02/23/2001 10 miles 02/23/2004 36010 miles
CLAIM HISTORY
10/12/2004 231744 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 77913 miles
08/14/2002 187181 0 J0627 - LIFTER, VALVE - BOTH BANKS - REPLACE 43439 miles
08/14/2002 187181 0 Z7905 - 5-DAY COURTESY TRANSPORTATION 43439 miles
07/13/2001 357213 # J6980 - VACUUM HOSE - REPAIR OR REPLACE 13851 miles
02/22/2001 A05148 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Old May 16, 2008 | 02:28 PM
  #460
1BADAZZSS's Avatar
VEHICLE INFORMATION
7820 E 171ST ST
(816) 331-4300
Site Code : 05279
CLAIM HISTORY
So does that mean the engine has been replaced?
