Check Re-Calls & Service History Here
Old Jan 16, 2008 | 12:20 PM
  #331
Originally Posted by 4.8T
called the numer at the bottom and they say mine doesn't have any open recalls and that i should go to the dealer. but its doing exactly what the recall says it may do.
Yours hasn't been involved in the re-call yet. It will be in the next phase sometime later this year. Keep in mind how many they have to do.
Old Jan 16, 2008 | 12:24 PM
  #332
Originally Posted by bearfoot
2003 z71 1GCEK14T13Z181636 any recalls or trouble
Hey friend...it looks good so far. No open re-calls...but let me know if I can help you any further....
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 11/07/2002 4 miles 11/07/2005 36004 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 11/07/2002 4 miles 11/07/2008 100004 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 11/07/2002 4 miles 11/07/2010 80004 miles
36/36000 FEDERAL EMISSION 11/07/2002 4 miles 11/07/2005 36004 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/14/2005 373431 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 8107 miles
05/16/2003 344062 # B7289 - HEADLAMP/COMPOSITE ASSEMBLY - LEFT - REPLACE 825 miles
11/05/2002 336320 # Z6999 - PDI RELATED FLUID ADDS 4 miles
10/22/2002 A81636 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old Jan 16, 2008 | 12:28 PM
  #333
Originally Posted by BigD50
1GKEK13Z94J236926..2004 gmc yukon 4x4....any open recalls or ideas?
No open re-calls, but you got a bit of a service history there. Look over it before you ever make a repair because some may be covered by an existing parts warranty.
RC 05037 SECOND ROW CENTER SAFETY BELT N/A Closed
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 02/20/2004 10 miles 02/20/2007 36010 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 02/20/2004 10 miles 02/20/2010 100010 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 02/20/2004 10 miles 02/20/2012 80010 miles
36/36000 FEDERAL EMISSION 02/20/2004 10 miles 02/20/2007 36010 miles
CLAIM HISTORY
01/02/2008 164447 0 D0362 - CONTROL, HEATER AND AIR CONDITIONING - REPLACE 62692 miles
01/02/2008 164447 0 Z7901 - 1-DAY COURTESY TRANSPORTATION 62692 miles
12/20/2007 356832 0 K4126 - ACTUATOR ASSEMBLY, TRANSFER CASE - REPLACE 61998 miles
10/12/2007 161921 0 F2383 - RING GEAR AND PINION - REAR DIFFERENTIAL - REPLACE 59212 miles
07/24/2007 350893 0 N6640 - WIRING AND/OR CONNECTOR - HORN - REPAIR OR REPLACE 56111 miles
07/24/2007 350893 0 E2320 - BEARING AND HUB ASSEMBLY, FRONT WHEEL - RIGHT - REPLACE 56111 miles
07/24/2007 350893 0 E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 56111 miles
05/16/2007 239060 0 J4340 - COIL, IGNITION - REPLACE 54112 miles
05/16/2007 239060 0 Z7902 - 2-DAY COURTESY TRANSPORTATION 54112 miles
02/20/2006 142126 # E0600 - HOLD-DOWN, SPARE TIRE - R&R OR REPLACE 36019 miles
02/20/2006 142126 # E0724 - SENSOR, LOW TIRE PRESSURE WARNING - REAR - RIGHT - REPLACE 36019 miles
02/20/2006 142126 # L2540 - SHIELD, MUFFLER - REPLACE 36019 miles
02/06/2006 141604 # N4010 - LIGHTER ASSEMBLY, CIGARETTE - REPLACE 35254 miles
02/06/2006 141604 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 35254 miles
09/16/2005 137115 # C6489 - PLATE/BEZEL, FRONT POWER SEAT SWITCH - LEFT - REPLACE 33552 miles
09/15/2005 137082 # N0410 - BULB, BACK-UP LAMP (RIGHT) - REPLACE 33552 miles
07/22/2005 135118 # V1382 - 05037 - STITCH SEAT LOOP CLOSED 33530 miles
02/19/2004 A36926 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old Jan 16, 2008 | 03:32 PM
  #334
BigD50's Avatar
Default Thanks
Thank you so much, that is very kind of you to do. Yeah I take advantage of my extended warranty as you can see haha. But hey I paid for it so now GM has to follow up with their end. Since you are a GM trained tech, could you tell me if I should go to a dealer and pay about 130-160 for a full cooling system drain, flush, and refill when other shops that are fairly reputable will do the same thing for about 80-120? Are the machines used at all different? I know the tech's are always better for the most part at dealer's and its always more pricey, what do you think?
Old Jan 16, 2008 | 04:02 PM
  #335
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Last one, I swear!
1GCGK13U95F829280
Old Jan 17, 2008 | 10:23 AM
  #336
Being honest......I can tell you that the Cooling System Flush at Mineke is the same as what we do here at my shop. Their Flush machine is made by SPX and ours is a GM Flushe machine, which is made by SPX Kent Moore....same ****! So just use a trustworthy shop, and not a backwoods garage and you'll get the same work at a cheaper rate, but keep in mind......your Diagnostics and Transmission work should be done at a GM Pro Shop for safer liability and workmanship warranty.
Old Jan 17, 2008 | 10:29 AM
  #337
Originally Posted by Neil 6.0
Last one, I swear!
1GCGK13U95F829280
lol...Neil 6.0....I think your a Info Addict.....you may need some Rehab...lol. No problem bro....your latest find looks like a sweet *** deal. Nothing uncommon...and the repairs so far are one's that you should be glad they've already made.
VEHICLE INFORMATION
Merchandising Model : CK15743 -2005 SILVERADO 1500HD 4WD CREW CAB Warranty Start Date : 12/21/2004
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : COVERT CHEVROLET, BUICK, PONTIAC, GMC
PO BOX J
BASTROP , TX 78602-1977
(512) 303-2311
Selling Source : 13 - CHEVROLET
Site Code : 30148
Business Associate Code : 114878
Service Contract : Yes Branded Title : No Warranty Block : No PDI Status : Paid
RC 05006 HYDRO-BOOST ACCUMULATOR OVER-PRESSURIZATION N/A Closed
OnStar Equipped No OnStar Status N/A Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID VH6G60HB XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 12/21/2004 18 miles 12/21/2007 36018 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 12/21/2004 18 miles 12/21/2010 100018 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 12/21/2004 18 miles 12/21/2012 80018 miles
60/50000 FEDERAL EMISSION 12/21/2004 18 miles 12/21/2009 50018 miles
CLAIM HISTORY
11/20/2006 211552 # N0761 - BULBS, STOP, TAIL, AND TURN LAMP (LEFT) - REPLACE 31151 miles
08/02/2005 183773 # V1382 - 05037 - STITCH SEAT LOOP CLOSED 9830 miles
08/02/2005 183773 # V1308 - 05006 - INSPECT HYDRO-BOOST - NO FURTHER ACTION REQURIED 9830 miles
09/13/2004 A29280 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old Jan 18, 2008 | 08:49 AM
  #338
2k4tahoe's Avatar
Originally Posted by Torque_Wrench
One re-call and it's been closed...but here's your info.
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 06/14/2004 5 miles 06/14/2007 36005 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/14/2004 5 miles 06/14/2010 100005 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/14/2004 5 miles 06/14/2012 80005 miles
36/36000 FEDERAL EMISSION 06/14/2004 5 miles 06/14/2007 36005 miles
CLAIM HISTORY
09/07/2006 185891 # E3807 - SHOCK ABSORBER, FRONT - BOTH - REPLACE 34335 miles
09/07/2006 185891 # E1730 - CROSSMEMBER, FRONT SUSPENSION - REPLACE 34335 miles
09/07/2006 185891 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 34335 miles
09/07/2006 185891 # C2684 - LENS, LAMP INTERIOR AND/OR REAR COMPARTMENT - REPLACE 34335 miles
09/07/2006 185891 # C6510 - ACTUATOR, FRONT SEAT BACK (MANUAL RECLINING OR RELEASE UNI 34335 miles
07/03/2006 180099 # D1002 - BLOWER MOTOR RESISTOR REPLACEMENT 30767 miles
02/24/2006 168469 # N0851 - BULB, FOG LAMP (LEFT) - REPLACE 24416 miles
02/24/2006 168469 # V1382 - 05037 - STITCH SEAT LOOP CLOSED 24416 miles
08/16/2004 500419 # R0760 - RADIO, REMOVE AND REPLACE 3231 miles
05/17/2004 A99274 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Pretty clean looking to me.
thanks again man, i try to keep it up as much as possible.
hey isnt there a speed o meter guage recall? i have heard other having problems and now randomly mine will mess up.
Old Jan 20, 2008 | 03:04 PM
  #339
BigD50's Avatar
For a proper flush of the cooling system my chilton's manual says that the thermostat should be removed...why is this and why do shops includind gm goodwrench dealers always tell me they dont do this when i ask?
Old Jan 20, 2008 | 03:47 PM
  #340
formerly 20032wdsilverado (8/29/2011)
i heard somewhere that you have to hold the rpm at 2500 for like 5 mins, then pop off the lower hose.
