Check Re-Calls & Service History Here
Old Nov 1, 2010 | 03:41 PM
  #1121
Originally Posted by jadaven
Hey Man, will you take a look at this. 04 Sierra 1GTEC14V84Z313159.
Thanks
Jim
Here you go my friend.
VIN: 1GTEC14V84Z313159 Model: TC15703-2004 GMC SIERRA 1500 2WD REG CAB PICKUP
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Vehicle has no current record of required field actions.
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Vehicle has no current record of OnStar / XM Radio information.
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Bumper to Bumper Limited Warranty 01/01/2005 23 MI 01/01/2008 36,023 MI
Emission Select Component Ltd Wty 01/01/2005 23 MI 01/01/2013 80,023 MI
Special Coverage-07187 01/01/2005 23 MI 01/01/2012 80,023 MI
Corrosion Limited Warranty 01/01/2005 23 MI 01/01/2011 100,023 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
12/26/2006 208424 ZREG----Regular Vehicle Transaction J3480 - Water Pump Replacement 35,645 MI
10/24/2006 206125 ZREG----Regular Vehicle Transaction E7700 - Shaft, Steering Intermediate - Replace 32,598 MI
03/15/2005 270703 ZREG----Regular Vehicle Transaction H2641 - Brake Pedal Assembly Replacement 2,198 MI
09/03/2004 A13159 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Old Nov 4, 2010 | 01:45 PM
  #1122
jadaven's Avatar
Thanks man
Old Nov 4, 2010 | 08:27 PM
  #1123
Jeteys5.3's Avatar
can you do a check on this one for me!
1GTHK29D46E205864
Old Nov 5, 2010 | 08:18 AM
  #1124
1GTHK29D46E205864
Got a little service history but nothing I'd worry about.
VIN: 1GTHK29D46E205864 Model: TK25753-2006 SIERRA 2500 EXT 4WD
Type Number Original Nbr Description Release Date Status
Product Emission Recall N060522 06522 ENGINE GLOW PLUG SYSTEM CONCERN - REPROGRAM GLOW PLUG CONTROL MODULE 03/27/2006 Closed
Branded Title
Warranty Block
Service Information
Diesel Engine Ltd Wty with Deductible 02/10/2006 389 MI 02/10/2011 100,389 MI
Bumper to Bumper Limited Warranty 02/10/2006 389 MI 02/10/2009 36,389 MI
Emission Limited Warranty 02/10/2006 389 MI 02/10/2011 50,389 MI
Emission Select State Component Lty Wty 02/10/2006 389 MI 02/10/2013 70,389 MI
Corrosion Limited Warranty 02/10/2006 389 MI 02/10/2012 100,389 MI
Service Contract
01/05/2010 023671 ZREG----Regular Vehicle Transaction J6270 - Exhaust Gas Recirculation Valve Replacement 43,021 MI
02/25/2009 016961 ZREG----Regular Vehicle Transaction D0362 - Heater and Air Conditioning Control Replacement 34,837 MI
12/10/2008 015345 ZREG----Regular Vehicle Transaction R0943 - Radio Front Side Door Speaker Replacement - Left Side 34,071 MI
12/03/2008 015209 ZREG----Regular Vehicle Transaction N6612 - Exterior Lighting Wiring and/or Connector Repair or Replacement 34,032 MI
11/12/2008 014740 ZREG----Regular Vehicle Transaction J4767 - Plugs, Glow (Diesel) - Both - Replace 33,626 MI
06/03/2008 011027 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 30,478 MI
06/03/2008 011027 ZREG----Regular Vehicle Transaction J0933 - Engine Oil Cooler Replacement 30,478 MI
04/02/2008 009599 ZREG----Regular Vehicle Transaction H1320 - Power Brake Booster Replacement 28,317 MI
03/07/2008 009043 ZREG----Regular Vehicle Transaction Z7903 - 3-DAY COURTESY TRANSPORTATION 28,101 MI
03/07/2008 009043 ZREG----Regular Vehicle Transaction K5392 - Lines And/Or Fittings, Transmission Oil Cooler - Lower - At Transmission - Repair Or Replace 28,101 MI
03/07/2008 009043 ZREG----Regular Vehicle Transaction R0944 - Speaker, Radio - Front Door Auxiliary Or Console - Right - Replace 28,101 MI
03/07/2008 009043 ZREG----Regular Vehicle Transaction K5390 - Lines And/Or Fittings, Transmission Oil Cooler - Upper - At Transmission - Repair Or Replace 28,101 MI
03/07/2008 009043 ZREG----Regular Vehicle Transaction T2020 - Towing 28,101 MI
04/13/2007 099337 ZREG----Regular Vehicle Transaction D1210 - Sensor, Outside Air Temperature - Replace 15,369 MI
07/12/2006 091882 ZFAT----Field Action Recall V1464 - 06522 - Reprogram Glow Plug Control Module 5,157 MI
02/17/2006 088050 ZREG----Regular Vehicle Transaction C1060 - Front Side Door Weatherstrip Replacement - Right Side 425 MI
02/17/2006 088050 ZREG----Regular Vehicle Transaction D1210 - Sensor, Outside Air Temperature - Replace 425 MI
01/26/2006 195254 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 2 MI
01/18/2006 A05864 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Old Nov 7, 2010 | 09:12 PM
  #1125
ap2002's Avatar
Can you check this please 1GCHK23608F127378
Old Nov 9, 2010 | 08:08 AM
  #1126
here you go friend....
Vehicle Information
VIN: 1GCHK23608F127378 Model: CK20743-2008 SILVERADO 2500 4WD CREW CAB
Customer Satisfaction Program N070320 07320 FRONT AXLE VENT TUBE KINKED - FLUID LEAK *****EXPIRES DECEMBER 31, 2008***** 12/20/2007 Closed
Service Update Bulletins N070286 07286 SUB-FRT AXLE VENT TUBE KINKED INV ONLY-EXPIRES 02/29/08-REPLACED BY 07320 11/05/2007 Closed
Customer Satisfaction Program N080142 08142 ECM EEPROM - REPROGRAM ECM 05/12/2008 Closed
Branded Title
Warranty Block
Service Information
Type Number Description Posted Date
EI PIE0109 FRONT BUMPER FASCIA PAINT 09/01/2010
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677).
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: 0K38W0C0 XM Status: Inactive
OnStar Vehicle Diagnostics: N DMN Enabled: N
Corrosion Limited Warranty 11/17/2007 159 MI 11/17/2013 100,159 MI
Diesel Engine Limited Warranty 11/17/2007 159 MI 11/17/2012 100,159 MI
Powertrain Limited Warranty 11/17/2007 159 MI 11/17/2012 100,159 MI
Bumper to Bumper Limited Warranty 11/17/2007 159 MI 11/17/2010 36,159 MI
Emission Limited Warranty 11/17/2007 159 MI 11/17/2012 50,159 MI
Service Contract
01/05/2010 062026 ZREG----Regular Vehicle Transaction K4163 - Rear Output Shaft Seal Replacement 72,436 MI
07/10/2008 046866 ZREG----Regular Vehicle Transaction E0716 - Diagnostic System Check - Tire Pressure Monitoring 22,151 MI
07/07/2008 046705 ZFAT----Field Action Recall V1819 - 08142 ECM EEPROM - Reprogram ECM 22,087 MI
01/24/2008 041634 ZFAT----Field Action Recall V1773 - 07320 Inspect/Repair Vent Tube and Inspect Front Axle – No Fluid Required 6,233 MI
09/04/2007 A27378 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Old Dec 2, 2010 | 07:01 AM
  #1127
Sunset01SS's Avatar
If you would run this VIN I would appreciate it, it's an Impala I hope to buy on Saturday.
2G1WF55E619253155
Thanks again.
Old Dec 6, 2010 | 09:08 AM
  #1128
2G1WF55E619253155
Thanks again.
Here you go Sir,
Vehicle Information
VIN: 2G1WF55E619253155 Model: 1WF19-2001 IMPALA SEDAN
Order Type: 50 - FLEET
Branded Title
Warranty Block
Service Information
XM Equipped: N XM Radio ID: XM Status: NA
Bumper to Bumper Limited Warranty 01/17/2001 10 MI 01/17/2004 36,010 MI
Special Coverage 05551 01/17/2001 10 MI 01/17/2011 120,010 MI
Emission Select Component Ltd Wty 01/17/2001 10 MI 01/17/2009 80,010 MI
Corrosion Limited Warranty 01/17/2001 10 MI 01/17/2007 100,010 MI
Service Contract
05/06/2004 041563 ZREG----Regular Vehicle Transaction L2300 - Converter, Oxidation Catalytic - Replace 81,721 MI
01/05/2001 A53155 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Old Dec 6, 2010 | 05:27 PM
  #1129
anthonyc's Avatar
Registered User
hey guys i have a 2007 cc nnbs silverado vortec max 4 wheels drive. i bought it new and since 07 i have put 18000 on the odmeter..anyways i am having a problem with every day atleast once hot or cold when i put the truck in reverse it like slips out and makes a grinding noise that sounds harendus..is there anything besides the fluid level i can check or might be wrong..this truck has the 4l70 with the 6.0 motor. vin# 2GCFK13Y771587792 i just want to know if they offered a service bulletun on it..i know its covered under warranty and i should just take it in but i really cant wait for the truck while its down! thanks tony c
Old Dec 7, 2010 | 02:57 PM
  #1130
Ieatpeople's Avatar
2010 silvy: 1GCPKPEA1AZ214513
just wanted to see if there are any recalls, or any entries at all. i got it "new" with 250 miles on it....
