Check Re-Calls & Service History Here
Old Sep 27, 2010 | 10:37 AM
  #1101
Originally Posted by jhe2003
Thanks in advance! I have a 06 trailblazer ss that I just picked up and would like to know some history on it! Thanks
1GNET13H962299383
This thing is a Garage Queen dude....
VIN: 1GNET13H962299383 Model: CT15506-2006 TRAILBLAZER 4WD
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Vehicle has no current record of required field actions.
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677).
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: KEX6H0CC XM Status: Inactive
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Emission Select Component Ltd Wty 04/17/2006 131 MI 04/17/2014 80,131 MI
Corrosion Limited Warranty 04/17/2006 131 MI 04/17/2012 100,131 MI
Bumper to Bumper Limited Warranty 04/17/2006 131 MI 04/17/2009 36,131 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
04/29/2009 279137 ZREG----Regular Vehicle Transaction C1140 - Weatherstrip - Rear Door Wheel Arch - Right - Align Or Replace 28,272 MI
04/29/2009 279137 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 28,272 MI
04/29/2009 279137 ZREG----Regular Vehicle Transaction N4180 - Instrument Cluster Replacement 28,272 MI
04/15/2009 278751 ZREG----Regular Vehicle Transaction N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 27,788 MI
04/15/2009 278751 ZREG----Regular Vehicle Transaction N6648 - Seat System Wiring and/or Connector Repair or Replacement 27,788 MI
04/15/2009 278751 ZREG----Regular Vehicle Transaction F9709 - Drain and Refill Rear Axle Fluid 27,788 MI
03/11/2008 266882 ZREG----Regular Vehicle Transaction Z7410 - GOODWILL OIL CHANGE 18,669 MI
03/11/2008 266882 ZREG----Regular Vehicle Transaction L1197 - Fuel Level Sensor Replacement 18,669 MI
07/18/2007 088963 ZREG----Regular Vehicle Transaction H0640 - Master Cylinder Replacement 13,548 MI
07/18/2007 088963 ZREG----Regular Vehicle Transaction H0042 - Pads, Disc Brake - Front - R&R Or Replace 13,548 MI
07/18/2007 088963 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 13,548 MI
06/29/2007 258412 ZREG----Regular Vehicle Transaction E0420 - Wheel Replacement 12,961 MI
04/12/2007 255473 ZREG----Regular Vehicle Transaction R5570 - Headphone Replacement 11,160 MI
04/12/2007 255473 ZREG----Regular Vehicle Transaction C6041 - Adjuster Assembly, Front Seat Power - Bucket Seat - Driver - R&R Or Replace 11,160 MI
04/12/2007 255473 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 11,160 MI
04/12/2007 255473 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 11,160 MI
01/30/2007 252842 ZREG----Regular Vehicle Transaction R5140 - Module, Vehicle Interface Unit VIU/VCIM - Replace 9,355 MI
01/09/2007 252155 ZREG----Regular Vehicle Transaction R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 8,636 MI
09/25/2006 248562 ZREG----Regular Vehicle Transaction F2223 - Differential Case Replacement 5,265 MI
09/25/2006 248562 ZREG----Regular Vehicle Transaction Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 5,265 MI
09/25/2006 248562 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 5,265 MI
08/23/2006 247433 ZREG----Regular Vehicle Transaction F2003 - Rear Axle Housing Cover and Gasket Replacement 4,412 MI
03/29/2006 242468 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 1 MI
Old Sep 27, 2010 | 12:10 PM
  #1102
denaliz1's Avatar
vin check please
2GTEK638671663124
thank you!
Old Sep 27, 2010 | 02:50 PM
  #1103
Originally Posted by denaliz1
vin check please
2GTEK638671663124
thank you!
Here you go
VIN: 2GTEK638671663124 Model: TK10543-2007 SIERRA SHORT BOX CREW CAB 1500 4WD
Field Actions: 1 Open
Type Number Original Nbr Description Release Date Status
Product Safety Recall N080048 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS 08/28/2008 Closed
Product Safety Recall N100153 10153 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - DISABLE AND REMOVE MODULE 06/08/2010 Open
Branded Title
Warranty Block
Service Information
Type Number Description Posted Date
EI PIE0109 FRONT BUMPER FASCIA PAINT (PIE0109) 09/01/2010
XM Equipped: Y XM Radio ID: 69E8T00V XM Status: Active
Powertrain Limited Warranty 04/24/2007 55 KM 04/24/2012 160,055 KM
Emission Select Component Ltd Wty 04/24/2007 55 KM 04/24/2015 130,055 KM
Corrosion Limited Warranty 04/24/2007 55 KM 04/24/2013 160,055 KM
New Vehicle Limited Warranty 04/24/2007 55 KM 04/24/2010 60,055 KM
Service Contract
12/17/2009 68396 ZREG----Regular Vehicle Transaction B4521 - Rear Side Door Outside Handle Replacement - Left Side 41,273 KM
12/17/2009 68396 ZREG----Regular Vehicle Transaction E8623 - Hoses, Power Steering Hydraulic - Return - Replace 41,273 KM
05/08/2009 057593 ZFAT----Field Action Recall V1993 - 08048A - Jumper Harness Installation 30,540 KM
05/08/2009 057593 ZREG----Regular Vehicle Transaction E0032 - Wheel Trim Cover Hub Cap Replacement 30,540 KM
04/10/2007 A63124 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 KM
Old Oct 5, 2010 | 02:12 PM
  #1104
OneBadSSS's Avatar
Torque, can you run these two VINs for me? One's the truck in my sig and the other is an '01 Blazer I just picked up for cheap that's in rough shape:
2GCEK19T021237033 and 1GNDT13W21K244308
Old Oct 6, 2010 | 09:29 AM
  #1105
Not a problem my friend...here's the first...
VIN: 2GCEK19T021237033 Model: CK15753-2002 SILVERADO 1500 EXT CAB 4WD
Product Safety Recall N040007 04007 TAILGATE SUPPORT CABLE 09/17/2004 Open
Product Safety Recall N050068 05068 FRONT WHEEL SPEED SENSOR CORROSION 09/22/2005 Closed
Branded Title
Warranty Block
Service Information
Vehicle has no current record of OnStar / XM Radio information.
Emission Select Component Ltd Wty 01/22/2002 26 MI 01/22/2010 80,026 MI
Corrosion Limited Warranty 01/22/2002 26 MI 01/22/2008 100,026 MI
Emission Select State Component Lty Wty 01/22/2002 26 MI 01/22/2009 70,026 MI
Emission Limited Warranty 01/22/2002 26 MI 01/22/2005 50,026 MI
Bumper to Bumper Limited Warranty 01/22/2002 26 MI 01/22/2005 36,026 MI
Service Contract
08/08/2007 021423 ZFAT----Field Action Recall V1410 - 05068 - Inspect Wheel Sensor (inc. cleaning) 82,000 MI
06/09/2004 091549 ZREG----Regular Vehicle Transaction E7700 - Shaft, Steering Intermediate - Replace 35,268 MI
11/29/2001 A37033 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
For this vehicle:
→ View Vehicle Summary
→ Service Contract
→ Branded Title
→ Warranty Block
→ View Vehicle Build
→ View Vehicle Component Summary
→ View Vehicle Transaction History Detail
→ View Vehicle Delivery Information
→ Add a Repair Item
→ Begin Transaction
→ Investigate Major Assembly History
Here's the second one....
VIN: 1GNDT13W21K244308 Model: CT10506-2001 4-DOOR 4WD BLAZER LS
Branded Title
Warranty Block
Service Information
XM Equipped: N XM Radio ID: XM Status: NA
Bumper to Bumper Limited Warranty 06/04/2001 31 MI 06/04/2004 36,031 MI
Corrosion Limited Warranty 06/04/2001 31 MI 06/04/2007 100,031 MI
Emission Select Component Ltd Wty 06/04/2001 31 MI 06/04/2009 80,031 MI
Service Contract
10/02/2003 119871 ZREG----Regular Vehicle Transaction N0110 - Battery Replacement 31,045 MI
10/02/2003 119871 ZREG----Regular Vehicle Transaction Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 31,045 MI
07/31/2003 117188 ZREG----Regular Vehicle Transaction C0131 - Front Side Door Window Outer Sealing Strip Replacement - Left Side 29,291 MI
07/31/2003 117188 ZREG----Regular Vehicle Transaction C0331 - Strip, Rear Door Window Outer Sealing - Left - R&R Or Replace 29,291 MI
07/31/2003 117188 ZREG----Regular Vehicle Transaction C3187 - Trim, Center Pillar - Right - Complete - R&R Or Replace 29,291 MI
07/31/2003 117188 ZREG----Regular Vehicle Transaction L2584 - Muffler - Single - Replace 29,291 MI
07/31/2003 117188 ZREG----Regular Vehicle Transaction C0130 - Front Side Door Window Outer Sealing Strip Replacement - Right Side 29,291 MI
07/31/2003 117188 ZREG----Regular Vehicle Transaction C4540 - Plate, Back Opening Sill - Replace 29,291 MI
07/31/2003 117188 ZREG----Regular Vehicle Transaction J9991 - Customer Concern Not Duplicated - Engine Mechanical 29,291 MI
07/31/2003 117188 ZREG----Regular Vehicle Transaction E2180 - Insulator And/Or Bracket, Front Stabilizer Shaft At Frame - Replace 29,291 MI
02/04/2003 110152 ZREG----Regular Vehicle Transaction J6090 - Valve, SAI Check - Right - Replace 22,233 MI
02/04/2003 110152 ZREG----Regular Vehicle Transaction J6050 - Secondary Air Injection Pump Replacement 22,233 MI
02/04/2003 110152 ZREG----Regular Vehicle Transaction J6120 - Hose, SAI - Replace 22,233 MI
02/04/2003 110152 ZREG----Regular Vehicle Transaction J6380 - Sensor, Oxygen (Catalyst Monitoring) - Replace 22,233 MI
02/04/2003 110152 ZREG----Regular Vehicle Transaction N1720 - Fuse Replacement 22,233 MI
02/04/2003 110152 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 22,233 MI
04/30/2002 098889 ZREG----Regular Vehicle Transaction N2355 - Switch - Multifunction (Instrument Panel) - Replace 12,787 MI
08/17/2001 088956 ZREG----Regular Vehicle Transaction J3140 - Engine Oil Cooler Adapter Replacement 3,575 MI
05/21/2001 A44308 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Old Oct 6, 2010 | 12:04 PM
  #1106
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
2GTEC19C571688480
Hope it's clean!!
Old Oct 7, 2010 | 09:25 AM
  #1107
OneBadSSS's Avatar
Thank you very much!!
Old Oct 7, 2010 | 10:55 AM
  #1108
carhea's Avatar
Registered User
Hi new here and was wondering if you could check my vin
1GTGK29U83Z330558
thanks very much
Old Oct 7, 2010 | 12:09 PM
  #1109
Originally Posted by Neil 6.0
2GTEC19C571688480
Hope it's clean!!
Here you go Neil...looks like the run of the mill
Vehicle Information
VIN: 2GTEC19C571688480 Model: TC10753-2007 SIERRA 1500 2WD EXT CAB PICKUP
Branded Title
Warranty Block
Service Information
EI PIE0109 FRONT BUMPER FASCIA PAINT 09/01/2010
Bumper to Bumper Limited Warranty 08/23/2007 187 MI 08/23/2010 36,187 MI
Corrosion Limited Warranty 08/23/2007 187 MI 08/23/2013 100,187 MI
Emission Select Component Ltd Wty 08/23/2007 187 MI 08/23/2015 80,187 MI
Powertrain Limited Warranty 08/23/2007 187 MI 08/23/2012 100,187 MI
Service Contract
12/16/2009 017392 ZREG----Regular Vehicle Transaction J6002 - Tube, Positive Crankcase Ventilation - Replace 30,864 MI
12/16/2009 017392 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 30,864 MI
05/04/2007 A88480 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Old Oct 7, 2010 | 12:11 PM
  #1110
1GTGK29U83Z330558
thanks very much
Here you go ....looks good.
Vehicle Information
VIN: 1GTGK29U83Z330558 Model: TK25753-2003 SIERRA 2500 EXT 4WD
Product Safety Recall N040007 04007 TAILGATE SUPPORT CABLE 09/17/2004 Closed
Branded Title
Warranty Block
Service Information
Special Coverage-07187 05/29/2003 210 MI 05/29/2010 80,210 MI
Corrosion Limited Warranty 05/29/2003 210 MI 05/29/2009 100,210 MI
Emission Limited Warranty 05/29/2003 210 MI 05/29/2008 50,210 MI
Bumper to Bumper Limited Warranty 05/29/2003 210 MI 05/29/2006 36,210 MI
Service Contract
04/20/2010 0497120 ZREG----Regular Vehicle Transaction T5680 - Instrument Cluster Assembly, GMT 800 Special Coverage Bulletin # 07187 53,909 MI
04/19/2010 234991 ZREG----Regular Vehicle Transaction T5686 - 07187 - Special Coverage Adjustment - Replace & Reprogram IPC (inc. Gauge Sweep Test) 53,786 MI
10/26/2004 038836 ZREG----Regular Vehicle Transaction B5800 - Endgate Handle Replacement 23,345 MI
10/26/2004 038836 ZFAT----Field Action Recall V1242 - 04007 - Inspect and Replace Tailgate Support Cables inc. Hinge Replacement if Necessary 23,345 MI
05/15/2003 A30558 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
For this vehicle:
→ Service Contract
→ Branded Title
→ Warranty Block
→ Add a Repair Item
→ Begin Transaction
