Check Re-Calls & Service History Here
Old Jul 20, 2010 | 09:52 AM
  #1071
ioio's Avatar
Registered User
Default Recall history
Hi Torque Wrench,
Can you please check on my Chevy?
VIN 1GCHK23U41F186602
Thanks
Old Jul 20, 2010 | 09:44 PM
  #1072
JS01's Avatar
1GCEC14JX8Z108994
Old Jul 21, 2010 | 10:42 AM
  #1073
Originally Posted by ioio
Hi Torque Wrench,
Thanks
Here it is....
VIN: 1GCHK23U41F186602 Model: CK25743-2001 SILVERADO CREW CAB 4WD 3/4 TON
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 70 - RETAIL - STOCK
Field Actions: 1 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Product Safety Recall N040007 04007 TAILGATE SUPPORT CABLE 09/17/2004 Open
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Vehicle has no current record of OnStar / XM Radio information.
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Corrosion Limited Warranty 10/23/2001 26 KM 10/23/2007 160,026 KM
Emission Limited Warranty 10/23/2001 26 KM 10/23/2006 80,026 KM
New Vehicle Limited Warranty 10/23/2001 26 KM 10/23/2004 60,026 KM
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
08/11/2004 152287 ZPTI----Part Transaction - Service Agent Installed N2355 - Switch - Multifunction (Instrument Panel) - Replace 119,284 KM
05/31/2004 149704 ZREG----Regular Vehicle Transaction B5750 - Support, Tailgate/Endgate Cable - One Or Both - Replace 111,192 KM
11/29/2003 142602 ZPTI----Part Transaction - Service Agent Installed N0200 - Horn Replacement 84,571 KM
05/21/2003 135562 ZREG----Regular Vehicle Transaction Add Credit F1280 - Propeller Shaft Assembly - R&R Or Replace 57,184 KM
05/21/2003 135562 ZREG----Regular Vehicle Transaction F1280 - Propeller Shaft Assembly - R&R Or Replace 57,184 KM
05/16/2001 A86602 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 KM
Old Jul 21, 2010 | 10:48 AM
  #1074
Originally Posted by JS01
Here you go sir....
VIN: 1GCEC14JX8Z108994 Model: CC10703-2008 SILVERADO 1500 2WD REGULAR CAB
Service Contract: Yes Branded Title: No Warranty Block: No PDI Status: No
Field Actions: 0 Open
Vehicle has no current record of required field actions.
Branded Title
Warranty Block
Service Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677).
OnStar Equipped: Y OnStar Status: Active
XM Equipped: Y XM Radio ID: HL74V0HU XM Status: Inactive
OnStar Vehicle Diagnostics: Y DMN Enabled: N
Emission Select Component Ltd Wty 09/21/2007 29 MI 09/21/2015 80,029 MI
Corrosion Limited Warranty 09/21/2007 29 MI 09/21/2013 100,029 MI
Bumper to Bumper Limited Warranty 09/21/2007 29 MI 09/21/2010 36,029 MI
Powertrain Limited Warranty 09/21/2007 29 MI 09/21/2012 100,029 MI
Service Contract
Policy Number: 816986317 Owner: TURNER
Description: GMPP 60/75 MAJOR GUARD Deductible Amount: 100.00
Effective Date: 09/21/2007 Expiration Date: 09/21/2012
Effective Odometer: 29 MI Expiration Odometer: 75029 MI
Daily Rental Limit: 35.00
11/13/2009 371458 ZREG----Regular Vehicle Transaction B1540 - Latch, Hood - R&R Or Replace 12,880 MI
11/13/2009 371458 ZREG----Regular Vehicle Transaction N6620 - Power and Grounds Distribution Wiring and/or Connector Repair or Replacement 12,880 MI
07/19/2007 A08994 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
Old Jul 21, 2010 | 03:37 PM
  #1075
SILVERADO11's Avatar
Torque Wrench could you run my other trucks VIN for me 1GCEC14T55Z105983 Thanks David.
Old Jul 22, 2010 | 07:31 AM
  #1076
With pleasure Sir....here you go....
VIN: 1GCEC14T55Z105983 Model: CC15703-2005 SILVERADO 1500 2WD
Branded Title
Warranty Block
Service Information
Corrosion Limited Warranty 10/30/2004 18 MI 10/30/2010 100,018 MI
Emission Select State Component Lty Wty 10/30/2004 18 MI 10/30/2011 70,018 MI
Emission Limited Warranty 10/30/2004 18 MI 10/30/2007 50,018 MI
Bumper to Bumper Limited Warranty 10/30/2004 18 MI 10/30/2007 36,018 MI
Emission Select Component Ltd Wty 10/30/2004 18 MI 10/30/2012 80,018 MI
Special Coverage-07187 10/30/2004 18 MI 10/30/2011 80,018 MI
Service Contract
10/14/2009 789204 ZPTI----Part Transaction - Service Agent Installed N4180 - Instrument Cluster Replacement 98,884 MI
12/28/2005 624795 ZREG----Regular Vehicle Transaction B4151 - Outside Rearview Mirror Glass Replacement - Left Side 27,449 MI
12/20/2005 622922 ZREG----Regular Vehicle Transaction R0755 - RADIO RECEIVER-RETURN TO AC/DELCO ESC-INCOMPLETE EXCHANGE 26,727 MI
12/12/2005 622922 ZREG----Regular Vehicle Transaction N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 26,727 MI
12/12/2005 622922 ZREG----Regular Vehicle Transaction Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 26,727 MI
12/12/2005 622922 ZREG----Regular Vehicle Transaction N4180 - Instrument Cluster Replacement 26,727 MI
09/26/2005 613615 ZREG----Regular Vehicle Transaction R0760 - Radio, Remove and Replace 21,997 MI
06/21/2005 249714 ZREG----Regular Vehicle Transaction K6360 - Seal, Extension Housing Rear - Replace 14,810 MI
04/07/2005 240137 ZREG----Regular Vehicle Transaction F1280 - Propeller Shaft Assembly - R&R Or Replace 8,707 MI
12/07/2004 131247 ZREG----Regular Vehicle Transaction B0860 - Rear Bumper Alignment 2,427 MI
12/07/2004 131247 ZREG----Regular Vehicle Transaction B0260 - Front Bumper Alignment 2,427 MI
11/08/2004 220318 ZREG----Regular Vehicle Transaction E0203 - Tire and Wheel Balancing - Four 480 MI
07/20/2004 A05983 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time
Old Jul 23, 2010 | 08:10 PM
  #1077
hawaiianstyle's Avatar
thanks Torque_Wrench, I'm pleased nothing is wrong at this time.
Old Aug 10, 2010 | 09:05 AM
  #1078
jacdelivery's Avatar
Registered User
could you run this vin as im thinking about buying but want to know if i can find out if the injectors have been replaced on this 03 duramax. thanks
1GTHK23133F153633
Old Aug 10, 2010 | 11:22 AM
  #1079
1GTHK23133F153633
Looks like this thing has had alot of repairs made bro.
VIN: 1GTHK23133F153633 Model: TK25743-2003 SIERRA CREW CAB 4WD 3/4 TON
Order Type: 50 - FLEET
Product Safety Recall N050037 05037 SECOND ROW CENTER SAFETY BELT 07/14/2005 Closed
Customer Satisfaction Program N050546 05546 15,000 MILE - 24,000 KM FUEL FILTER CHANGE **IN EFFECT UNTIL SEPT. 30, 2006** 08/10/2005 Closed
Product Safety Recall N040007 04007 TAILGATE SUPPORT CABLE 09/17/2004 Closed
Branded Title
Warranty Block
Service Information
Corrosion Limited Warranty 11/21/2002 20 KM 11/21/2008 160,020 KM
Emission Limited Warranty 11/21/2002 20 KM 11/21/2007 160,020 KM
New Vehicle Limited Warranty 11/21/2002 20 KM 11/21/2005 60,020 KM
Diesel Engine Ltd Wty with Deductible 11/21/2002 20 KM 11/21/2007 160,020 KM
Special Coverage 04039 11/21/2002 20 KM 11/21/2009 320,020 KM
Special Coverage 07187 11/21/2002 20 KM 11/21/2009 112,020 KM
Service Contract
05/08/2007 724221 ZREG----Regular Vehicle Transaction J0497 - Sleeve, Fuel Injector - Right Bank - Replace 112,688 KM
05/03/2007 724021 ZREG----Regular Vehicle Transaction K5228 - Switch, Park/Neutral Position - Replace 112,342 KM
05/03/2007 724021 ZREG----Regular Vehicle Transaction Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 112,342 KM
03/22/2007 722353 ZREG----Regular Vehicle Transaction Add Credit J3480 - Water Pump Replacement 105,124 KM
03/22/2007 722353 ZREG----Regular Vehicle Transaction J3480 - Water Pump Replacement 105,124 KM
03/09/2007 058440 ZPTI----Part Transaction - Service Agent Installed J3363 - Hose, Engine Coolant - Lower - Replace 103,307 KM
02/16/2007 056610 ZFAT----Field Action Recall V1382 - 05037 - Stitch Seat Loop Closed 101,751 KM
12/14/2006 051621 ZREG----Regular Vehicle Transaction J6000 - Valve, PCV - Replace 101,003 KM
12/14/2006 051621 ZREG----Regular Vehicle Transaction J5888 - Turbocharger Coolant Feed Pipe Replacement 101,003 KM
01/20/2005 023919 ZFAT----Field Action Recall V1242 - 04007 - Inspect and Replace Tailgate Support Cables inc. Hinge Replacement if Necessary 74,560 KM
01/20/2005 023919 ZREG----Regular Vehicle Transaction Full Debit J4355 - Crankshaft Position Sensor Replacement 74,560 KM
01/20/2005 023919 ZREG----Regular Vehicle Transaction J4355 - Crankshaft Position Sensor Replacement 74,560 KM
11/08/2004 065783 ZREG----Regular Vehicle Transaction Z7902 - 2-DAY COURTESY TRANSPORTATION 69,634 KM
11/08/2004 065783 ZREG----Regular Vehicle Transaction Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 69,634 KM
11/08/2004 065783 ZREG----Regular Vehicle Transaction Full Debit Z7901 - 1-DAY COURTESY TRANSPORTATION 69,634 KM
11/08/2004 065783 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 69,634 KM
11/08/2004 065783 ZREG----Regular Vehicle Transaction J7801 - Diesel Fuel Injectors - Diagnose and Replace all 69,634 KM
11/08/2004 065783 ZREG----Regular Vehicle Transaction J5560 - Fuel Pressure Regulator Replacement 69,634 KM
06/17/2004 037055 ZREG----Regular Vehicle Transaction Full Debit Z7901 - 1-DAY COURTESY TRANSPORTATION 54,848 KM
06/17/2004 037055 ZREG----Regular Vehicle Transaction Z7901 - 1-DAY COURTESY TRANSPORTATION 54,848 KM
06/17/2004 037055 ZREG----Regular Vehicle Transaction E2327 - Front Wheel Bearing and Hub Replacement - Both Sides 54,848 KM
02/11/2004 S99972 ZREG----Regular Vehicle Transaction Z7903 - 3-DAY COURTESY TRANSPORTATION 42,732 KM
02/11/2004 S99972 ZREG----Regular Vehicle Transaction N1720 - Fuse Replacement 42,732 KM
02/11/2004 S99972 ZREG----Regular Vehicle Transaction Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 42,732 KM
02/11/2004 S99972 ZREG----Regular Vehicle Transaction K7121 - Pump, Transmission Oil - R&R Or Replace 42,732 KM
01/05/2004 S98992 ZREG----Regular Vehicle Transaction Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 41,284 KM
01/05/2004 S98992 ZREG----Regular Vehicle Transaction N9995 - Customer Concern Not Duplicated - Electrical 41,284 KM
01/05/2004 A98992 ZPTI----Part Transaction - Service Agent Installed J0950 - Oil Filter Replacement 41,284 KM
12/03/2003 S98300 ZREG----Regular Vehicle Transaction Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 38,271 KM
12/03/2003 S98300 ZREG----Regular Vehicle Transaction N1720 - Fuse Replacement 38,271 KM
12/03/2003 S98300 ZREG----Regular Vehicle Transaction F2122 - Differential Carrier Overhaul 38,271 KM
12/03/2003 S98300 ZREG----Regular Vehicle Transaction E3520 - Upper Control Arm Replacement 38,271 KM
11/12/2003 S97717 ZREG----Regular Vehicle Transaction Z7902 - 2-DAY COURTESY TRANSPORTATION 37,134 KM
11/12/2003 S97717 ZREG----Regular Vehicle Transaction J5650 - Fuel Injector Replacement 37,134 KM
09/04/2003 S95770 ZREG----Regular Vehicle Transaction D1180 - Switch, Pressure Cycling - Replace 31,060 KM
06/24/2003 246872 ZREG----Regular Vehicle Transaction N0528 - Bulbs, Lamp - Exterior - Replace 21,772 KM
01/28/2003 148741 ZREG----Regular Vehicle Transaction Z7903 - 3-DAY COURTESY TRANSPORTATION 7,055 KM
01/28/2003 148741 ZREG----Regular Vehicle Transaction F2122 - Differential Carrier Overhaul 7,055 KM
11/06/2002 A53633 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 KM
Old Aug 11, 2010 | 01:43 PM
  #1080
Registered User
thanks for the last one torque. i just found another d-max do you mind runnin it for me? thanks. 1GCHK23133F103251.
