Can i fit 33s
Old May 9, 2014 | 05:56 PM
Offroadunleashed's Avatar
Default Can i fit 33s
I have an 06 silverado 4wd 1500 and have a leveling kit.will the wells fit 33s or do i need to get a body lift?
Old May 9, 2014 | 06:25 PM
FFDP's Avatar
What size rims do you run?
I know you'd be able to fit 285's pretty darn easy with 16's, 17's and 18's.
Might have to trim just a really small amount of the front lower plastic on the bumper.
Factory size's are normally 265's.
Old May 9, 2014 | 06:26 PM
I have 17s. The reason I ask is I was looking a general grabbers
Old May 9, 2014 | 06:38 PM
FFDP's Avatar
I don't see an issue with running that size. Look up one of those conversion charts for tire sizes. You might just have to lower the sidewall height a very small amount to keep it safe and keep the overall diameter of the tire the same.
Old May 9, 2014 | 06:59 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
The fitment will mostly depend on the width & offset of your wheels. Minor trimming will usually be necessary, but if you need more room you can always look into the "NorCal fender mod". Should come up in a google search.
Here's my HD2500 with 33x12.50R18's at stock height.
Old May 9, 2014 | 08:18 PM
I love the rims btw
Old May 31, 2014 | 11:41 PM
904Lay'dbackZ's Avatar
How do you post pics I have a 01 ford keys 3/4 up lift shocks running 37/1250/17 bfg barely rubbed at full turn
Old Jun 1, 2014 | 09:24 AM
thewrx's Avatar
Just leveling kit
Old Jun 1, 2014 | 11:44 AM
black00chev's Avatar
Slowest turbo build ever!
I had 33's on my old truck, it had a 3" body lift and the front tires would just barely rub when turning while backing up. That was the only time it did it. Tires were 285/75-16 I believe.
Old Jun 1, 2014 | 12:03 PM
BattleSausage's Avatar
Should be fine, I run 285/70/17 on my Z with nothing other than the factory leveling kit and have never had a problem. Have A/Ts on now and had M/Ts on before without problem as well.
