It came back...
Old Oct 4, 2006 | 08:10 AM
Gran Patron's Avatar
We get one or two vehicles a day with the clunk sound from the steering wheel and all we do is retorque and relube the shaft. Problem goes away for almost about a year before it comes back again.
Old Oct 4, 2006 | 02:32 PM
Zick's Avatar
Found this over at www.thedieselplace.com, seems they have been using this with good luck.
This just might be the final fix for that POS steering shaft.
http://www.borgeson.com/TruckProductChevy.htm
Old Oct 4, 2006 | 02:37 PM
Zick's Avatar
Actually Endo on here found it at Summit for cheaper.
http://store.summitracing.com/egnsea...115+4294907434
Old Oct 4, 2006 | 02:40 PM
Nick™'s Avatar
Originally Posted by slowec
Yea OK, And revove the front end to do a engine job. The book way is not always best. I worked @ stealership for 10 years and I am a ASE master technician. I think I know my way around a Gm steering shaft. More than one way to skin a cat. I stand behind my method. Taking it all the way out is only needed if you can't push the lube in. My 36 " prybar works great. I have only done this a hundred or so times so I could be wrong
yeah, and looky here, it's back 1 year later
Old Oct 4, 2006 | 03:51 PM
shandy294's Avatar
Originally Posted by 99Silver6.0
Im putting a grease zerk on mine!!!!!!!!!
Will a zerk work in this application? It seems like it would've been done if it worked. It's too bad GM didn't come up with a permanent fix for this.
Old Oct 5, 2006 | 03:14 PM
shandy294's Avatar
Bump...installing a grease fitting won't work?
Old Oct 5, 2006 | 03:57 PM
bigredexpress99's Avatar
no. when you regrease them, you have to compress the shaft to pack it.....no go on the zerk.
Old Oct 5, 2006 | 05:17 PM
shandy294's Avatar
Thanks
Old Oct 8, 2006 | 09:41 PM
ranwalk's Avatar
Hey smart ***, I work at a dealer. Do it your way all you want to. Techs like you doing it wrong is what caused this simple problem to get blown out of proportion. I have yet to see one come back that was done correctly. Too many times I have had them return doing it the short cut method.
Old Oct 8, 2006 | 10:21 PM
99Silver6.0's Avatar
I drilled a small hole and tapped in a zerk. I greased it with a hand pump grease gun............ Grease squeezed out the splined end. There isnt a negative clearance between the splines. So there is room for it to squeeze out. Mine was clunking. Now it magically stopped. Ill stick to greasing it myself when needed rather than hassle with getting it to the dealer. Did the same on my friends 2000. Worked on it too. Im not paying $200 some odd dollars for a steering shaft.
