Cabin lights don't turn on
Since it's dark now when I come home from work, I've noticed that my interior lights don't turn on when I open either door. They do however turn on when I hit the lock button on the key fob, but only for a couple seconds.
I'm not sure what the normal operation of the interior lights is with respect to the doors, locking/unlocking, key in/out of ignition, etc. But there is a problem.
Could this be a bad BCM? Everything else seems to be working just fine.
Well the interior lights worked perfectly fine today on the way home. I didn't touch the dome override button, it is currently pushed out. The interior lights also come on when the dimmer switch is turned all the way up as they should.
Kinda sounds like a burnt up dimmer switch. You may have un-crustified the dimmer circuit if you rolled it, since the whole shebang is built together.
03regcab sierra
20
Aug 3, 2015 12:11 AM
atxlt
Jul 20, 2015 11:06 PM
Suburban2500
Jul 14, 2015 02:10 AM
