A/C wont stop blowing air
Ok heres my problem yesterday I drove my truck and turned on the a/c everything was working fine so I get home and shut the a/c off before i turn the truck off like ussual and notice that the blower kept blowing I then turn the truck off and still the blower is blowing so at this point I am asking myself WTF is going on. I then disconnect the battery for about 5 minutes and then re-connect back up and same problem the blower wont stop blowing I played around with the a/c/ controls but nothing this thing just wont stop blowing I took out the blower fuse which is in the fuse box under the hood which made it stop blowing, anyone have any ideas of what could be going on?
I would agree with Tootall, I believe that harness has 12v all the time, if the harness itself melted bad enough it could be making contact with one of the other wires, thus making stay on all the time...
I'll bet my hairdo (I'm bald
)that you're going to find the wires going to the blower resistor melted and shorted, you'll want to replace the resistor and splice in the new harness. There were a few threads in this section about this problem recently, but usually guys lose some fans speeds, or all speeds but high, etc. If you search probably a few threads down, you should find some inexpensive options and links to the parts you need
Thanks guys I will try and take a look at it this weekend.
I did try searching but i found alot of threads talking about the blowers speed but mine was different it just wouldnt turn off Im guessing a new resistor and new harness should do the job.
TrickTurbo
Sep 23, 2015 08:41 PM
MA$TER_E
Sep 9, 2015 03:14 PM
Hpinnovate
Sep 4, 2015 02:28 AM
