A/C problem...HELP!
Old Mar 14, 2007 | 11:28 AM
Whitestreak98's Avatar
Default A/C problem...HELP!
the a/c in my 98 gmc sierra hasnt worked in the past few months and i dont kno what the problem is... it doesnt blow out of the dash or defrost... only the floor. there is no a/c only "cool" air and hot air... and the lights on the push in buttons dont light up. i think that is about it... so please help me in any way possible! thanks
Old Mar 14, 2007 | 03:34 PM
You've got an AC Door Actuator that has gone bad. Sounds like the Blend Air Door Actuator. But to be sure you need to test the AC Control Head in your dash. It could be bad also.
Old Mar 14, 2007 | 10:49 PM
would i do that thru a GM Dealer or is there a specific sort of shop i need to take it to? bout how much are each pricewise? let me hear ya torque_wrench...
Old Mar 15, 2007 | 10:28 AM
You'll prob be better off letting a dealership do it. My guys do these alot at my dealership so, we get it done a little faster than others.
You're probably looking at about $150 to $200 for the AC Door Actuator, and it's about 3 to 4 hours labor involved in dropping the heater box under the dash and replace it.
It's a headache but this actually does happen alot. If you need anything else just write it up or PM me.
Old Mar 19, 2007 | 09:46 PM
willymac's Avatar
is your compressor kickin on when you push the a/c button, if not the panel could be out, the panel would also cause the blend actuator to not move to the upper vents
FormulaZR
Sep 14, 2015 05:23 PM
Hpinnovate
Sep 4, 2015 02:28 AM
creekrat
Aug 2, 2015 01:27 AM
