but load of dtc's
Old Jan 30, 2008 | 03:20 PM
TURBHOE's Avatar
Default but load of dtc's
what is with all of these.
[Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Restraints] U1096 - Loss of Communications with IPC (History) (Immature)
[HVAC] B3770 - (History) (Immature)
[HVAC] B0229 - (History) (Immature)
[HVAC] B3531 - (History) (Immature)
[HVAC] B3764 - (History) (Immature)
[HVAC] B0429 - Temperature Control Rear Circuit Range/Performance (History) (Immature)
[HVAC] B0434 - (History) (Current) (Immature)
[Convenience] B1850 - Driver Lumbar Horiz Sensor CKT Malf (History) (Immature)
[Convenience] B1960 - (History) (Immature)
[Convenience] B2425 - (History) (Immature)
**edit* figured out the first two. it was from when i pulled the cluster out to look at it.
Old Jan 30, 2008 | 04:02 PM
Zick's Avatar
Are you using HP Tuners?
If you are see this thread; http://www.hptuners.com/forum/showthread.php?t=6766
Probably just BCM codes that you don't need to worry about.
Old Jan 30, 2008 | 04:30 PM
TURBHOE's Avatar
yeah, hpt. but my lumbar doesn't work, my seat heater doesn't work, and my rear heat blows cold all the time no heat at all.
Old Jan 30, 2008 | 05:49 PM
Zick's Avatar
Well then I'm guessing that's why you are getting those codes.
Sorry not sure what to check besides fuses for the seat problems.
Infernohoe
48
Oct 2, 2015 10:25 PM
Lthompson
Oct 2, 2015 12:45 AM
Velocity1
Sep 22, 2015 01:32 PM
Lthompson
Sep 15, 2015 07:55 PM
creekrat
Sep 10, 2015 12:59 AM
