Brakes and brake lines..........
Old Apr 7, 2016 | 10:21 AM
About20ninj45's Avatar
Originally Posted by FFDP
Never tried the braided steel lines but new front rubber lines are worlds better than some old 100K mile rubber lines.
Most the of braking performance comes down to the pad/rotor combo. Better pads do so much to improve stopping power. Perhaps looks into a higher end set.
Regular DOT 3 fluid is just fine. Unless you think you'll be putting some serious heat into the brakes with racing or towing heavy loads down hills and risk boiling the fluid.
Dot 3 and dot 4 can be used. Higher end set arent always the greastest... especially compared to say your inhouse made brand..
For the tests I run, I see long heat cycles and more wear attributed to "higher end" brakes.
Old Apr 7, 2016 | 03:49 PM
Mark Johnson's Avatar
got a bit of an education on that- as it turned out, DOT 5 was actually not an improvement for systems like ours then 5.1 was created...........
Old Apr 10, 2016 | 03:24 PM
Lines finally got here yesterday, just had another big idea; thinking maybe the rotors are not warped as there's no shudder when I grandpa around but coming down from speed it's very exaggerated. So I'm thinking, the tires out of balance being transferred to the chassis via the solid clamp mounting at the wheel. Is my thinking correct..................
Old Apr 10, 2016 | 05:52 PM
slick_sierra's Avatar
Stainless braided lines up front, slotted rotors, semi metallic heavy duty pads, fluid flush and a good bleed ur pedal will be feelin great. Just did all that plus all new rubber coated lines and a new master cylinder on my truck
Old Apr 11, 2016 | 09:31 AM
MikeGyver's Avatar
When you say coming down from speed, do you mean 55 mph or 120 mph?
Stock rotors will heat warp from high speed, and return relatively to normal flatness when they cool off. I don't remember how many times you have to heat them before they become permanently warped.
Old Apr 11, 2016 | 05:55 PM
Anything 50 or more. All water under the bridge now as I was taking everything apart and found the right front totally munched; so I have a new pair on the way................
Old Apr 18, 2016 | 11:19 AM
Everything finally came in all done and bled. Less effort is needed to stop AND more stopping power is available. B4 no matter how much ya kept on pushing the pedal there was just so much stopping power available, almost on par with Mom's Denali............
Old Apr 18, 2016 | 12:17 PM
Past the point of no return..................
Old Apr 18, 2016 | 09:21 PM
dantheman1540's Avatar
Yeah those rotors were completely shot! Lines look good I was really pleased with them on mine glad they worked for you to!
Old Apr 19, 2016 | 12:59 PM
Yeah- I couldn't be happier, next item on the list is the door(s) as I've adjusted the stryker pin every which waybut now I'm concluding that it's not sure what it's called, latch, here's a pic.............
OneBadSSS
Mar 22, 2017 11:15 PM
Wyttrash96
Mar 24, 2016 06:28 PM
2002_Z28_Six_Speed
Mar 20, 2016 09:49 PM
Big Chuk
Mar 19, 2016 01:42 PM
timothy5
Mar 18, 2016 12:38 AM
