View Poll Results: Sould I go through the hassle since I have all the parts?
You're Crazy
0%
Go For it!
100.00%
Voters: 2. You may not vote on this poll
Body Harness swap questions..
I'm going to try and describe this the best I can.. And before you guys Say I should just buy a truck with all the options I wanted, keep In mind I bought this truck for 500$ and Its in great shape. has 150k and all It needed was a front wheel hub.
The truck is a 2005 silverado WT 1500 RCLB 2wd truck I bought for 500$ its a v6 as well. no options only cruise and A/C.
What i want it to be is:
6.0l/4l80e
power windows
power locks
heated mirrors
fog lights
steering wheel controls
power seats
Basically LOADED!
The past few months I've been doing my homework but its a bit spotty and waiting on people to respond to resurrected threads takes forever. so far what I gather is that if you take power doors (03-06 since truck is 05) and plug them into a non power door truck after reprogramming the BCM they will work.. EXCEPT the WT edition trucks. therefore the dash harness needs to be swapped out.
I buy a **** load of gen3 truck engines from this particular wrecking yard here so they decided to Hook me up after explaining my plans. They gave me two 2003 front Denali doors. loaded with the Denali logo on the door panels, Denali center console, all the dash trim and the heated leather seats. as well as a ENTIRE 2005 silverado LS 4 door cab with all the goodies in it all for 150$$ Wahoooo!! Everything on my list is in this trucks cab.
Now to my questions. First, My truck is a 2 door 2wd. the cab I'm pulling the harness and accessories out of is a 4 door 4x4. Will this be a huge problem? or can I tastefully delete the unneeded wires or hide them in kick panels?
do you think Ill have a hell of a time keeping ABS and airbags in check?
Do I reprogram the BCM to a 2door VIN or to a 4door vin. Or do I just leave the BCM alone because it matches the harness and options already?
Now into the engine questions. I have read through alot of v6 to v8 swap threads and have that down. I replace 5.3's and 6.0l's in these trucks all the time. i know my way around them very well. From what I understand if the truck is 99-02 you simply remove the v6 harness and plug in a 99-02 V8 harness for DBC and 03-06 engine harness to a 03-06 truck because of the DBW. but on a thread on Performancetrucks.net a guy posted that the fuse locations on all the 99-06 trucks are the same and if the 05 v6 is DBC like mine is then you can use a 99-02 harness instead of installing the pedal. Is this true? I forgot to mention I already have the stage 5 Trick performance turbo kit on my shelf for this build and the engine and trans. wouldn't DBC be better for turbo?
6.0l/4l80e
power windows
power locks
heated mirrors
fog lights
power seats
Basically LOADED!
ive done the power conversion on my 04. i bought a dash harness, which includes both inside fuse blocks and bcm off an 05 ext cab. its best if you try to get all the options close to what you have such as airbags and ac. since the ac plugs are different between manual ac and digital ac.
i just swapped harness and did a bcm relearn procedure and worked like a charm. any extra wires i just left as is. I do have the airbag light on since the 05 didnt have the airbag switch on the dash like my 04 does.
Custm2500's Rude Friend
You need to use parts from similar year donor's.
The 99-02 interior wiring is different from the 03-07 classic. Even some of the options such as the factory Bose stuff require special programing. Same with the AC, manual Vs. Digital
As far as the PCM, If you want to retain the DBC stuff when you swap from a V6 to V8, Use a Van Operating System as they were DBC. Just have the V6 PCM reprogrammed as it will support the DBC operating system. Not all the 1MB 03-07 classic PCM's will support the DBC.
ARC
57
02-21-2022 10:54 AM
GreyChevy
07-07-2015 08:57 PM
Nimoryan
07-05-2015 03:50 PM
