Blinker semi flashers
Old 04-01-2010, 03:12 PM
Where's the Beef?
viciousknid's Avatar
Default Blinker semi flashers
When I turn my left blinker on it will be flashers for about two blinks and then be a blinker. Suspect something up with the column. See this before?
Old 04-01-2010, 03:18 PM
Dewey's Avatar
never heard of it before. have you tried replacing the bulbs yet?
Old 04-01-2010, 03:31 PM
Wearin' da big hat
00ChevyScott's Avatar
The flasher for the emergency flasher and turn signals are usually different (ie 2 seperate flashers). You could try replacing those (since they're cheap) but they're doubtfully the issue here. You might need to pop the cover off the column and see if you've got any shorted wires or lose connections.
Old 04-01-2010, 04:20 PM
charcoal03silvy's Avatar
replace a module or a light is out?
Old 04-01-2010, 04:39 PM
Where's the Beef?
Thanks. I'll have a look at that stuff.
I check the blinkers every other fill up so I'll be checking them again soon.
Old 04-01-2010, 05:21 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Replace the hazard switch. Seen this before.
Old 04-01-2010, 05:35 PM
03chevyroyce's Avatar
mine does it occasionally, but instead of just blinking 2x, the hazards stay on until i turn off the blinker
oh yeah, and its left side for me too^^
Old 04-01-2010, 05:54 PM
Where's the Beef?
glad I'm not the only one. Usually if it doesn't stop I just turn it off and on again and it works like it should. Will look into the Flasher switch since it is right there on the column as well.
How hard is it to get that cover off?
Old 04-01-2010, 06:09 PM
Evil Eric's Avatar
I have seen really odd stuff happen when the ground wires for those lights become loose or detatched. Might want to check those.
Quick Reply: Blinker semi flashers
