best way to tow truck?
12 Second Club
so im moving my wife here soon and i need to know the best way to tow her truck here, its a 02 rcsb 2wd. i was just gona get a tow dolly and hook it behind the moving truck but my buddy told me it would burn up the tranny if i did that because there will be parts moving in the tranny and no fluid pumping. i could just pull the drive shaft and not worry about it or will it be fine to just put it up on the dolly, put it in neutral and make the 1200 mile trip?
I don't think the U-haul trailers are rated for a full size truck though. I ran into this problem when I bought my last RCSB. I was going to use a 3/4 ton truck to tow the RCSB back with, but the U-haul rental trailer wasn't rated to carry the RCSB.
The only way I could have done it would have been to drive my little Honda Accord to get the truck and tow the Accord on the trailer pulled by the newly purchased RCSB. The U-haul car trailer was rated to handle the Accord, but not the RCSB.
I'm just guessing, but I'll bet a U-haul tow dolly isn't rated to handle a full sized truck either.
I ended up finding another driver and we drove both back with no trailer.
Cliff notes: Use someone other than U-haul if you want to haul a full size truck on a trailer.
isnt better to disconnect the shaft from the differential and tigh the shaft up to the chassis or bed cause if im not mistaken doesnt it leek tranny fluid if u pull out the shaft and have the truck in an angle from the dolly
12 Second Club
well im using budget truck rental and they said that they wont give me a dolly or a full size trailer so i am just gona tell them that we will be towing my firebird and then put the truck on it. so ill prolly just unbolt the drive shaft and strap it to the frame, do you think that will be ok?
Suburban2500
07-19-2015 04:50 PM
07NBSChevy
20
07-08-2015 07:27 PM
