Bent Frame...
#21
Custm2500's Rude Friend
Originally Posted by wayland1985
Anybody have experience with bent frames? i'm convinced it'll just open doors for more problems down the road, and think I should trade her in, after 3 months and it's second accident. What do you guys think?
I have fixed the type of damage you are describing and as long as you took it to a competent shop It should be just fine. I have personally seen brand new trucks as far as 6 mills out in one direction from square. + or - 3 mills from square on a unitized car is generally industry standard. How ever I personally would not like to see a truck frame more then 5 mills out a only becuase trucks have more of a fudge factor. Dont get me wrong you want it as close to square as possible but it is not always possible to it perfectly square and have everything fit corectly. For example My brand new 2000 Chevy S10 was 15 mills out of spec in the back from the factory. But Everything fit just fine and if you tried to pull it back to spec nothing would have lined up. The main things are that they try to repair the frame with out using heat as much as they possible can and remove any kinks buckless or slight deformations that may appear on the frame rails. If it took a shot in the trailer hitch, they should have replaced the hitch and used the NEW hardware that comes with it. A bent hitch should NEVER be repaired... Hope its fixed to your likeing.
FlowmasterMufflers
11-24-2015 01:00 PM
Tim94gt
23
09-18-2015 04:51 PM
FlowmasterMufflers
09-18-2015 02:31 PM
FlowmasterMufflers
09-11-2015 03:32 PM
