BCM wont accept theft deterent
Old Dec 15, 2008 | 09:53 AM
viciousknid's Avatar
Where's the Beef?
I remember seeing threads on Pass Lock but had no idea what it was.
Now that I'm interested, I cant find them.
Old Dec 15, 2008 | 10:01 AM
Where's the Beef?
Found one. This was the procedure to put the BCM into learning mode. But with the differences TW mentioned it may not work. But worth a try.
Try the BCM learn procedure:
- turn key from off to ON;
- bump the key to START without actually starting (bump the starter);
- if engine did not start, then BCM enters learning mode phase 1;
Then:
- after about 10 minutes, the security indicator flashes,
- turn key OFF, wait a few moments, turn key to ON,
- repeat these 2 steps 2 more times [phases 2 and 3] (a total of 30 minutes)...
Old Dec 17, 2008 | 07:50 PM
I dissabled the VATS, at first the fob did't work: like I expected it wouldn't. But now the fob is lock/unlocking the door like normal. So I locked it with the window rolled down, reached in and unlocked and opened the door and the alarm went off. I checked the tune and it verrified that the VATS was turned off so I went and reloaded the tune and still the same. Now what?
Old Dec 17, 2008 | 08:29 PM
Where's the Beef?
The Vats wouldn't be whats causing the key fob not to work. It's my understanding that you program the fob to the bcm, New bcm, new programming required.
Try this
http://www.programyourremote.com/
A guess really.
Old Dec 17, 2008 | 08:54 PM
Try this
A guess really.
No, at first the fob didn't work but now it does as does the anti theft cause the alarm went off. I called the dealer and they said that with the VATS dissabled the fob shouldn't work either
cheyenne383
Nov 13, 2015 09:24 AM
Staggered 02
Oct 9, 2015 05:19 PM
03chevytruck
Sep 14, 2015 09:15 PM
03chevytruck
Sep 10, 2015 10:18 PM
