Is this bad?
Old Aug 29, 2011 | 02:47 PM
j_ahlheim's Avatar
Default Is this bad?
Does this sound bad to you. I'm worried its a lifter or valve or something because its only on the passenger side. The drivers side is hardly noticable and may just be the passenger side echo.
Old Aug 29, 2011 | 08:47 PM
j_ahlheim's Avatar
50 views and no opinions? does the link not work?
Old Aug 29, 2011 | 09:22 PM
Team Paulie's Avatar
Registered User
Did the intake and charger come all together or did you have to put it together,are the injecters seated all the way?
Does the noise go away on throttle or change pitch or tone?
I had a flex plate go out and one shop told me lifters,another told me injectors, flex plate was busted around five outta six bolts, but it changed tone and pitch under throttle,off throttle in gear and different tone in D or R.
Old Aug 29, 2011 | 09:23 PM
06murder's Avatar
sounds like the charger to me man...or the pully nothing i hear you should be worried bout...but if its lifters ur hearing try change the oil to something different
Old Aug 29, 2011 | 09:34 PM
Registered User
I was thinking its the injectors, some trucks are louder then others.
Old Aug 29, 2011 | 09:36 PM
06murder's Avatar
i was think that to,mine stock 5.3 has that lil sound its annoying...man i wouldnt worry bout it....might needing injector cleaning..
Old Aug 29, 2011 | 11:08 PM
j_ahlheim's Avatar
injectors are brand new came with the kit and already installed on the charger. I have always heard valvetrain noise more after the long tubes but thats because the material is thinner then stock manifolds. It just has me worried because its only on the passenger side.
Old Aug 29, 2011 | 11:17 PM
2007chevy5.3l's Avatar
Sounds like valve train noise to me.. Take the valve covers off and check over everything. Make sure theres nothing obvious..
Old Aug 29, 2011 | 11:56 PM
j_ahlheim's Avatar
when you say obvious you mean what? I have done all the work on my truck with the exception of the tuning and the paint but the internals of the engine and heads is something that is out of my experience level.
Old Aug 30, 2011 | 12:28 AM
Preston129's Avatar
Sounds normal to me. Does it go away after it heats up fully or after driving for a while? I heard valve train noise when mine was stock (stock valve train that is). Mostly when started from cold though.
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Chevy305
Sep 28, 2015 09:21 PM
