anyone ever run these tires on are trucks?
Old Apr 15, 2008 | 01:12 AM
trxmxzx's Avatar
13 Second Truck Club
Default anyone ever run these tires on are trucks?
http://www.tirerack.com/images/tires...o_a6_ci2_l.jpg
http://www.tirerack.com/tires/tires....e1=yes&place=0
well I was at a friends dads buddys house picking up some things that he barrowed from me and I was told he does autocross and I needed to come by and check his setup out well anyways I get there all I see is 4 transams modded -2 old school cars and 2 newer ones with the ls1 in them... This guy pulls in his drive way with 74 of these hoosier tires Im thinking jackpot!!! I might have found some tire to play with on the drag strip was talking to him a little and hes goes through 4 sets of tires every month!!! and he only uses them for 2-3 races and they have about 2/32nds left if not more on average, and then tosses them Im like WTF give them to me so It looks like I hit the jackpot if these are any good. I figured they would be better than street tires that i have with a treadwear of 520!
specs
275/45ZR16 LL
Treadwear: 40
Traction: C
Temperature: A40 C A
1477 lbs.Load Max.
44 psi Inflation
4/32" Tread depth
24 lbs. Tire weight
8-10.5" Rim Width Range
9" Meas. Rim Width
11.2" Sect. Width
10.3" Tread Width
25.3" Overall Diam
what do you all think
Old Apr 15, 2008 | 01:32 AM
James B.'s Avatar
Kind of small, don't you think? It's going to look odd everywhere but Texas, Arizona, and Mexico. They'd be sure fun in the rain.
Old Apr 15, 2008 | 01:35 AM
Stoichiometric's Avatar
Good compound, small tire, stiff sidewall.
Old Apr 15, 2008 | 01:38 AM
trxmxzx's Avatar
thats what I was thinking the height was a little low! what do you think that would put the gear ratio at?
Old Apr 15, 2008 | 01:42 AM
Go to Yahoo and punch in gear ratio calc and then enter your info.
Old Apr 15, 2008 | 06:42 AM
SnakeOiler's Avatar
They are car tires. Just because it is free, doesn't mean it is something you should use.
Old Apr 15, 2008 | 07:13 AM
beastmode's Avatar
Import Moderator
Are you planning on running them just at the strip... I was running a 26" tall tire at the strip (255/50/16) with 3.73s and it seemed to be just about perfect. Imo it wasnt that bad... but I have a 2/4 drop and I really could care less what the truck looks like at the track. Those are on a 8" wide wheel as well
Old Apr 15, 2008 | 09:24 AM
trxmxzx's Avatar
just wanted to run them just for the strip, ill be doing a 2-4 also after this motor swap
I was basically wondering if anyone has ran thses tires for drag other than autocross
Old Apr 15, 2008 | 05:38 PM
sv650lex's Avatar
I say for free, throw a set on all 4 and go find some corners.
Old Apr 15, 2008 | 08:36 PM
SnakeOiler's Avatar
I guess using them only on the strip wouldn't be so bad. But they are autocross tires - probably better than a street tire, maybe not as good as a drag radial, but for free I guess that's OK
