Any advice on getting me to 11s all motor
Hey guys and girls I just wanted to get some opinions and sight from the quarter mile crowd.My truck personal best so far is 12.69 1.8 60 ft and I would to make it to 11s all motor and with the same set up hopefully!Heres the run down of the truck and mods so far...it’s a ls1 with hand ported 799 heads,comp cam dual valve springs and hardened push rods,nnbs intake,ls7 throttle body with the x link,224/228 600 lift,60e built by Pepe Torres running a yank 3600 and a tru track with 410s.btw this truck is a 03 Silverado swb southern comfort edition so it’s got ac and all electric and I run with the tailgate off just for a quick weight reduction and it makes it easier to see the water box when I back up stock height truck just 2 inch drop shackle.the tire I run is a 29/10.5-15 Hoosier.alright with that being said what else could I possible do to get closer to my 11 na goal??the only thing I haven’t done yet that I can think of is a underdrive crank pulley and remove ac belt when I get to the track?Thanks in advance furcany tips or tricks I may have missed.
Well my truck does bounce up and down a little on take off but no wheel hop I’m gonna do the speed engineering traction bars and shock relocation kit and see if it helps my 60 ft time not too sure on how much power it’s making it only goes 104 in the quarter.I did improve my 60 for time from 1.87 to 1.80 just by removing my sway bar that was a freebie
Probably not by enough to justify the cost
some spit ball ideas:
run e85 with an appropriate pump/injectors and tune: put her on a dyno and maximize timing
keep messing with pressures and weight balance to get the 60' down. Fuel is your biggest ballast, mess around with more or less to see if she likes anything. Tire pressure > all. Chalk the tire/ wheel to make sure you're not spinning in the tire
Pop the pass headlight out, run a bell mouth on the intake tube. This got a shitbox 4cyl I had from 16.1 to 15.5 back in high school: def worth a shot
take the mirrors off, run bigs&littles
get a junk hood, cut all the ribbing out and vent it (less drag, allows air through the rad out the vent in the hood)
