Alternator voltage on a GMT800
Old Feb 26, 2016 | 08:53 AM
someotherguy's Avatar
Default Alternator voltage on a GMT800
Not sure if I asked this before, if I did, mind blown and forgot. Sorry in advance.
I've been doing a lot of searching to see what kind of running voltage others are seeing on their GMT800's. My 2006 Silverado SS is delivering just a hair over 15V running, like 15.1~15.2, which feels like just a bit too much. I'm used to seeing 14.0~14.2 on most vehicles, but this is my first GMT800 so I'm not sure if it's "normal" or not.
And I mean measured with a voltmeter at the battery with the engine running and all possible extra loads turned off like lights, stereo, A/C fan, etc.
Thanks!
Richard
Old Feb 26, 2016 | 09:14 AM
Flewbyu123's Avatar
Normally you should see about 13.6v to 14.2v .. 15.6v and above can do some damage to your electrical system.. I would have that checked.
Old Feb 26, 2016 | 10:02 AM
03sierraslt's Avatar
My 2004 sees 14.2-14.3
Old Feb 26, 2016 | 12:19 PM
Atomic's Avatar
I have a gauge for that
Mine is usually 14.5v at first start (when its recharging the battery) and about 13.5 after a while.
Over 15 is not good, you may have a broken regulator in the alternator or something.
Old Feb 26, 2016 | 12:32 PM
Wolftrk99's Avatar
^^^ what he said... If you turn any loads on can you hear a high pitched whine?? My 99 would put out almost 16v at times and if any load came on it would start whining, ended up killing the battery overcharging it before i had money and time(at same time) to upgrade to the 145 amp... Oddly the new alternator was less than a reman!!!
Old Feb 26, 2016 | 02:50 PM
Yeah I had a suspicion this was not normal. It's been running like this though for who knows how long; bought the truck a few thousand miles ago.
Gonna put a fresh battery in my voltmeter just to be sure, and check it again, before swapping out the alternator.
Richard
Old Feb 26, 2016 | 06:37 PM
George C....'s Avatar
Formerly ScreamingL
If going off stock cluster dont
Old Feb 27, 2016 | 10:52 AM
Not sure what this means, except if you're asking whether I'm looking at the voltage on the cluster. Nope. Using a multimeter, at the battery. Never trust dash gauges.
Richard
Old Feb 27, 2016 | 11:29 AM
Formerly ScreamingL
personally wouldnt sweat 15.1 v, toss a load on the truck and watch it drop to 14.5
Old Feb 27, 2016 | 07:20 PM
Suburbazine's Avatar
That's too high for a stock alternator and power system. Should be down around 13.8-14.2.
My custom alt runs at 14.8 because my idle load is about 80A haha.
