ahh oh
better get it going. I think I might be able to give you some competition. I think the only thing that will restrict you is your heads and the stock ECU and maybe fuel. Are you gonna do anything about the fuel system or keep it the same? I am anxious to see what you can do.
single digit dreamer
i have the twin intank set up from racetronics, not sure what it will goto but a single inline will goto 600+rwhp so i would think 700+rwhp easy.
injectors should be good for 700+rwhp
turbo should be good for 700+rwhp
megasquirt(DIY ECM) can handle 22psi in it's current set up and run low impeadance injectors whenever i am ready to slap them in.
Heads will probably hold me back a little and my single 3" down pipe. i have some ideas on the down pipe but heads are awile off.
this is going to be sooooo much fun.
I dunno man, I hope it all works as planned. But personally i dont see that fuel system giving you the fuel you are gonna need with as much boost as you wana run and that MAF is gonna kill you I think.
the way i see it everything i have like the turbo, injectors, fuelsystem will all max out about the same time. 700-800rwhp. thats kinda nice they all match up but that is a lot of stuff to upgrade if i want to push it harder.
i want some consistant 10's, see what problems i run into with that. then see what it will really do.
