Addding Foglights
Old Aug 25, 2007 | 09:13 AM
03GMC's Avatar
Default Addding Foglights
My truck came without fogs. I got in a accident and have to replace the bumper. Im going to get the bumper with the holes for fogs. How do I get working foglights in a truck that didnt come with them? Thanks!
Old Aug 25, 2007 | 11:56 AM
mdwatts11's Avatar
You can get a kit from the dealer that has the wiring, lights, and switch. I put it on my last truck, and it is pretty easy to install. I'm not exactly sure of the part number or price, but it is definitely worth it. Someone on here will know the part number. Let me know if you have any questions..
Old Aug 25, 2007 | 12:36 PM
03GMC's Avatar
Oh ok cool. I just got a Job at a Dodge dealership so I get parts at cost plus 10% at the Chevy place next door.
Old Aug 27, 2007 | 07:47 AM
Make sure you get the Dealership to reflash your BCM for the Fog Lamp option or they won't work.
Old Aug 27, 2007 | 10:11 AM
mdwatts11's Avatar
I didn't have them flash mine, and they worked like a champ. I even did the $1 6 high mod that is on a thread on here. They worked great...
Old Aug 27, 2007 | 10:40 AM
Nick™'s Avatar
there is no need to reflash the BCM for the 03+ trucks
I bought my kit on ebay and added the lights, I like the look of it and a little extra light on the road doesn't hurt anything.
Old Aug 27, 2007 | 11:30 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Wouldn't think there's a need to even go through the BCM for an aftermarket kit. Wire to an IGN circuit & +12V relay to the lights (w/ switch). Design solved.
Old Aug 27, 2007 | 02:30 PM
Nick™'s Avatar
he's talking about using an add on kit to use stock fog lights.
the kit will include the two lights, wiring harness and dash switch. the only wiring you install is to the underhood fuse panel to the lights and a ground, then the switch plugs into the same place the cargo light switch is and whamo, it works
Old Aug 27, 2007 | 03:40 PM
My 2003 and my 2005 GMC's both had to be re-flashed. And....we just did a 2005 here in my shop and had to do a re-flash to get them to burn. Odd maybe....anything is possible.
Old Aug 27, 2007 | 05:09 PM
95ImpSS's Avatar
Ahh... that's just it. I guess it depends... I wouldn't see why you'd have to flash a BCM to do that. I'll go and look at the schematics and see. I could be clueless of the foglight loop(<--- likely ). I assume the reason for this is b/c of the power conservation feature (kills power to electrical past 20 mins of no occupant use... i.e. if you left lights on... makes sense).I would just assume that's on a relay circuit tho, but this is GM we're talking about.
