AC System Actuator Re-Sync Procedure
Old 10-13-2009, 11:19 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
Sticky'd
Old 10-13-2009, 12:23 PM
Thanx, Most Admired Mod..lol....you'd be suprised how many times I get asked about this every week......
Old 11-16-2009, 06:10 PM
charcoal03silvy's Avatar
I'm going to do a temporary half *** fixed. I'm just gunna close the flap. But how do i get to it???? its the drivers side that doesn't blow hot
Old 11-17-2009, 08:28 AM
Oh man, it's a bitch! I hate doing those bastards. You gotta go in from the heater box, which is under your dash on the passenger side. It's a couple of long hours my friend.
Old 11-17-2009, 08:35 AM
Well damn, but its probably worth the effort then paying the stealer several hundred bucks.
So instead of a half assed fix i should do install the new actuator since its such a long process?:nunchuk1:
Old 11-17-2009, 11:59 AM
Brother, if I was going to go all the way inside that heater box just to close the door, hell I'd put the new actuator in there while I was already in that shitty mess.
Old 11-17-2009, 06:09 PM
Figured haha, its like a 100 dollar part?
Old 11-18-2009, 11:53 AM
Probably, but you may be able to get it cheaper.
Old 11-18-2009, 01:37 PM
i'll try pulling the fuse to try and recalibrate it to make sure i do need the part after school
Old 06-25-2017, 11:06 PM
Registered User
Yankee44NY's Avatar
Default Will this process need to be repeated ?
hey guys, I've had alot of questions about this in that past few weeks, so I decided to just post u[p the Re-Park or Re-Sync Procedure for the AC Motors. If you're having propblems with the air mode or temp modes, in your AC HVAC system, try this before you go to another drastic decision. Usually this corrects the problem without having to see a GM Service facility. If you Moderators are reading, you may want to add this to a Sticky Thread. Anyways...below is the info you seek....lol.
Actuator Recalibration
When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following:
Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
Place the ignition switch to the OFF position.
Disconnect the scan tool.
Install the HVAC control module.
Connect all previously disconnected components.
Start the vehicle.
Wait 40 seconds for the HVAC control module to self-calibrate.
Verify that no DTCs have set as current DTCs.
When replacing the HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC actuator be sure to perform one of the following:
Preferred Method (w/ Scan Tool)
Clear all DTCs.
Place the ignition switch in the OFF position.
Install the HVAC actuator.
Start the vehicle.
With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
Alternate Method (w/o Scan Tool)
Clear all DTCs.
Remove the HVAC/ECAS fuse for a minimum of 10 seconds.
Install the HVAC/ECAS fuse.
Start the vehicle.
if you can't get the new actuator to line up with the door location ?
RustyD
05-23-2016 07:04 PM
Avalanche2002
11-30-2015 07:31 AM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
blackedoutchevy22
10-01-2015 08:07 PM
carid
10-01-2015 09:22 AM
Quick Reply: AC System Actuator Re-Sync Procedure
