AC question...not cold!
Old Jun 28, 2005 | 07:23 AM
Mike_J's Avatar
Default AC question...not cold!
I have an 05 LT model with the digital temp controls. It recently got prety warm outside and was the first time I used the air when it was real hot. With the auto feature it had kicked on before but not when it was this hot out. Anyhow, I turned it down as far as it would go (60* F) and it blew at full strength and never got cold. It never got cool in the cab. I'm guessing this is not normal?
Anyone else with a similar expirence with thiers?
Mike
Old Jun 28, 2005 | 08:34 AM
facn8me's Avatar
You need to check the air temp coming out of the vent's. You may have a blend door problem letting warm air mix. With a r134a system 40-48* on max at 2k rpms after a min or so would be working correctly. Anything above 52ish and i would hve that sucker checked.
It takes a bit to cool of my 03 but will get cold in the cab. My windows are tinted also.
Skip Fix
22
Jul 9, 2016 07:08 PM
turbo6c3
Oct 5, 2015 06:11 PM
Raiderjim
14
Sep 26, 2015 10:18 PM
Closer_2001
Sep 24, 2015 09:15 PM
fortune46x
Sep 16, 2015 08:18 AM
