AC question
Old Sep 21, 2007 | 07:51 PM
03 BLACKOUTSSS's Avatar
Default AC question
I noticed that when I turn on the AC that engine starts to vibrate, and when I rev the engine, in neutral or drive, that I get "chatter" or a "rattle". It sounds like REALLY BAD clutch chatter on a new clutch (in transmission terms).
I have a feeling I know the answer, but I wanted some opinions.
Its the compressor going bad, isn't it.
Old Sep 22, 2007 | 08:41 PM
C'mon guys, I need some expertice here. I have another question. If the AC still blows cold, and the compressor only rattles when the AC is on, is it repairable? I have noticed that they sell a few different types of bearings for the compressor. Does this sound like just the bearings are wasted to anyone.
PS, if someone can post up an exploded parts view of the compressor, that would be awesome.
Thanks
Old Sep 22, 2007 | 09:25 PM
budhayes3's Avatar
PT's Slowest Truck
Get a stethoscope or long screwdriver and listen by both the compressor and tensioner pulley, could be either or (be careful by the moving parts obviously). I had my tensioner go bad and it sounded like a jackhammer with the ac on...if the tensioner is the problem, it's a piece of cake to replace and fairly inexpensive.
Old Sep 22, 2007 | 10:06 PM
Superado's Avatar
11 Second Truck Club
same noise here...I've got a new tensioner and belt for my a/c in the truck floorboard right now...
Old Sep 22, 2007 | 10:11 PM
Thats VERY good to know. I will check that first thing in the morning
Old Sep 23, 2007 | 12:19 PM
MonteCarlo31's Avatar
i've though about going to a goodyear gatorback belt (like you use on a blower) as I get quite the sqeek for about 20 seconds in the AM only when the A/C is on. Does anyone know why GM has the a/c on it's own pulley setup?
Old Sep 23, 2007 | 01:44 PM
Yogi Bear's Avatar
Because the A/C compressor takes so much power to run. Also, with a single belt, it's hard to get enough "wrap" around the compressor pulley for good contact area.
Old Sep 24, 2007 | 05:55 PM
not to hijack but I did notice the power it draws, my f-150 a/c on or off i got the same fuel economy, now it's almost 2 mpg difference. Why is this?
Old Sep 24, 2007 | 09:28 PM
By turning on the AC, you draw more on the crank (that phrase was not intentional). It takes power to run the AC. My mileage only changes by 5 to 10 miles per tank. Its not that significant.
Old Sep 25, 2007 | 03:56 AM
WODY's Avatar
your compressor has seized and has probably broken your tensioner too. bad news but its common. you'll need a new compressor, accumulator, orifice screen, and possibly a tensioner.
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
