AC question
Old Apr 5, 2005 | 08:34 PM
JK021500HD's Avatar
Default AC question
I installed my 05 E-fans with the Nelson harness controlled with my PCM tuned from Nelson. Since I have done this and been using my AC alittle bit the last week or so the clutch has been cycling off and on continously. The pass side fan comes on when ever the clutch is on for the AC, today it was 64 degres outside do you think that my AC should be cycling off and on every 30 seconds or stay on longer? Should I get it looked at? Do you know what the pressure for the gas is on the high and low side?
JK
Old Apr 5, 2005 | 09:27 PM
SnakeOiler's Avatar
The compressor clutch cycles on and off all the time. It's not a problem. What I want to know is why you are using your a/c when it's only 64 degrees?
The compressor clutch will also cycle like that when you set the switch over to defroster mode - even when the a/c is off.
Old Apr 5, 2005 | 10:13 PM
rosscob's Avatar
Sounds pretty normal. That fan is loud, so now you notice it. As soon as tax season is over I am going to try to find another way to activate that relay using the A/C request instead of the compressor. Then the fan will stay on with the A/C request from the HVAC system instead of cycling with the compressor. I don't think it will be quite as bothersom.
Old Apr 5, 2005 | 10:57 PM
SnakeOiler's Avatar
A/c request circuit is only 8.8 volt - won't work. not enough to energize the relay. That's exactly what I wanted to do.
Old Apr 6, 2005 | 07:27 AM
rosscob's Avatar
Thanks for saving me the trouble!
Old Apr 6, 2005 | 08:29 AM
KySilverado's Avatar
JK
JK, normal. Your AC compressor will cycle like this even in dead of winter with heat on high if you are using defrost unless you disable the AC. Annoying with the e-fans. I just posted this in another fourm, I am going to try and limit the fan cycling when not needed.
Guys,
I have the 05 E-fan in my truck with the Nelson wiring harness. As it is wired the passenger side fan comes on high every time the A/C compressor locks. There have been posts about the voltage drop with this and the 105 amp alternator, which I am goinging to upgrade. Another I noticed yesterday on a long road trip and the first time I've used A/C for extended period is that the fan also comes on regardless of highway speed. There is no need for the fan to come on with air moving accross the condenser at highway speed.
I plan on putting a thermostat in the A/C condenser in series with the A/C lead. Allowing the fan to kick on only if the temperature is high enough. Does anyone know a source for such a thermostat. The kind that goes through a radiator like I've seen used with the aftermarket fan kits. Anybody know what temperature I should use to kick fan on and off for the A/C condenser?
__________________
03 Silverado, ECSB, Z71, 5.3L,G80 W/3.73's, MagnaCharger @ 8psi, Corsa Catback,
Vette Servo, Dynatech SuperMaxx, 05 Electric Fans
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
