AC help
AC help
Need some expert help here...The car has 11xk miles and has never had trouble before. When on "auto" the car will switch from cold to warm. Then when you restart the car it works fine...
Any help?
Thanks Jason
Any help?
Thanks Jason
Thanks. How many "blend door actuators" does this vehicle have? I would assume one. Also, where is it located?
11 Second Hall Moniter
Jason, if you look on the headliner, you will see little things that look like small speaker grilles. They are HVAC air temp sensors. Have you ever heard any of them making clicking sounds? They seem to go bad often, and can make the HVAC system do strange things.
At any rate, the system is computer controlled, and likely has a failure code stored in the computer. If you can find anybody with a Tech2 scanner, try to get the code. That is the best place to start diagnosing.
