ABS problem
Old Dec 3, 2007 | 02:07 PM
SmokinHot98's Avatar
Default ABS problem
When I come to a stop if I hit a bump the truck hops and the ABS kicks in with very little brake pressure applied. This past Saturday we had the snow/ice storm sorta I guess but I was going to the local parts store and I started to brake to turn in the lot and I barely hit the brake and the ABS kicked in like crazy and I started to slide all over. My question is is there a snesor that picks up vibrations or something that would make the ABS kick in with no sliding of the tires? I know they shouldn't be kicking in this easy. Its was kinda freaky b/c had there been a car in front of me I would have hit them when my brakes w/o ABS kicking in would have stopped me just fine
Old Dec 3, 2007 | 06:05 PM
Anyones
Old Dec 3, 2007 | 08:36 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
sounds liek your abs brake control module going out
Old Dec 3, 2007 | 08:39 PM
RandomHero's Avatar
not really. Sounds to me like you're abs wheel sensor is dirty. It's a little sensor on your wheel hub. It gets dirty sometimes and gives false abs readings. You can clean it or buy a new one on ebay or something.
Old Dec 3, 2007 | 09:00 PM
budhayes3's Avatar
PT's Slowest Truck
+1, There's actually a recall on earlier model NBS trucks for this exact problem. Rust and dirt builds up on the front abs speed sensors and reluctor wheels and gives false readings causing premature abs activation and over sensitive abs control.
Old Dec 3, 2007 | 09:05 PM
RandomHero's Avatar
Yup, good thing is that it's a lot easier to replace than a abs module or pump.
Old Dec 3, 2007 | 09:15 PM
Piss Pumps for Sale
yeah I often forget about the wheel sensors, I almost thought I had a bad abs modul a while back, so its usually the first thing that pops into my head.
Old Dec 3, 2007 | 09:19 PM
RandomHero's Avatar
me too usually. I had an abs module go out.
Old Dec 4, 2007 | 07:26 AM
thanks guys. I have to get that fixed so I don't have to worry about scary moments in the snow again that and my Eaton LSD is on its was so no more 1 wheel wonder
RustyD
May 23, 2016 07:04 PM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Blklgt
Sep 28, 2015 03:21 PM
