ABS / Brake light on?
Old Jul 13, 2011 | 07:06 AM
lady3bglover's Avatar
Default ABS / Brake light on?
Has anyone dealt with this issue before? I slowed to make left hand turn and these popped on, and are still on.
Old Jul 13, 2011 | 08:30 AM
TXsilverado's Avatar
ive been looking at these lights for about 5 years now lol. too lazy/cheap to fix it. search ebay for abs module repair. it's usually about 125 if i remember correctly. the lights being on doesnt hurt anything, but when they are on, your ABS brakes do now work properly.
Old Jul 13, 2011 | 08:58 AM
1Bear's Avatar
In some cases the issue can be caused by a faulty ground from the ABS module to the frame rail and would be the 1st thing I would check, but it’s also a good possibility you will end up following Stewart’s suggestion towards needing your ABS module repaired.
Old Jul 13, 2011 | 09:03 AM
from what ive seen, the faulty ground only sets the ABS light, not the ABS and brake lights together. its totally possible though and easily checked. the main ground of concern is just below the body mount on the drivers side on the front side of the cab. dont tighten it too tight as it is easily stripped out. just pull the bolt, make sure everything is clean and snug it up.
Old Jul 13, 2011 | 05:25 PM
budhayes3's Avatar
PT's Slowest Truck
First thing I would do is scan the ABS module for a code...may be as simple as a bad sensor, broken wire, etc. But, as our buds said above, the module and ground issues are very common When my ABS module went, it caused the ABS pump to run continuously (I just unplugged it since I had crawled under there to see what is going on, but I could just as easily pulled the ABS fuse under the hood )
Old Jul 13, 2011 | 11:02 PM
oldred95's Avatar
Mine self diagnosed itself when it started running the ABS pump motor and both lights came on at the same time. I pulled the maxi fuse and drove it for a couple months until I got the whole BPMV and EBCM together for 100 bucks from the salvage yard. Its been on there over 2 years and through countless ABS events and hasn't let me down. Pretty much if you've got a 99-02 and the ABS and red brake warning lights are on plan on replacing the EBCM.
Old Jul 13, 2011 | 11:05 PM
charcold-bowtie's Avatar
Just picked up a 2000 and it has just the ABS light on. Sounds like I possibly found my solution. Thanks
Old Jul 15, 2011 | 06:21 PM
ha.. my light went to normal a couple of days ago... hmmmm. figures.
Old Jul 16, 2011 | 10:27 AM
it will come back on eventually. mine is hit or miss. ill drive it 300 miles without a light, then for weeks it will light up backing out of the driveway.i need to send mine in.
Old Jul 17, 2011 | 01:49 AM
GmJackson53's Avatar
Im suprised no one thought of a speed sensor?
