99-02 Manual Brake Help
it has Russel braided flex lines that I put on probably 4 or 5 years ago. I’ll go around and check that something didn’t damage them while the wife pumps the brakes.
wardlws (08-04-2023)
I’m gonna look for some kind of calculation similar to finding brake PSI. When I did my braking psi calculation, everything checked out but volume may be another story and the math doesn’t lie.
I found a brake calculator of sorts today and started fiddling with it. It’s an excel work sheet from Busted Knuckles Off Roads website. Going by their guidelines I should be aiming for an overall leverage of around 190 for manual brakes.
With all my stuff plugged in I’m at 119 with a stock bore size (1.338”) and a 6.4:1 pedal ratio. Not good.
Now if I drop the bore size down to 1 inch, I get about a 212 overall leverage. Much better and that’s a 78% gain.
Guess I’ll be looking for a smaller master cylinder.
strutaeng (08-05-2023)
'12 AWD Platinum Escalade
Here is the brake calculator that I used when I upsized my MC and rear calipers: https://www.tceperformanceproducts.com/bias-calculator/
I agree that it sounds like your Master Cylinder size may be too large diameter.
