98 Fuel pump assembly
Old Apr 15, 2012 | 07:08 PM
HRV-LS1's Avatar
Default 98 Fuel pump assembly
I'm in the middle of installing an LM7 5.3 from a 03 Suburban into my 95 GMC
Sierra. I live in California, and need the smog stuff. One thing, will a 98 fuel pump/sending unit work with my 95? ( will the pump run and fuel gauge work)?
Gentlemen, what do you think?
Old Apr 15, 2012 | 08:21 PM
skinny chicken's Avatar
Bump for a good dude trying to find an answer
Old Apr 15, 2012 | 09:26 PM
Put a 98 up truck tank and truck fuel pump in yours and everything will work correctly. You will have to change the fuel lines at the tank but that's no problem. The 98's use quick connect fittings just cut the metal lines off on the frame from the donor truck and use compression fittings to put them on your truck and you will be good to go.
The 95 tank will not accept 98 pump.
Old Apr 15, 2012 | 10:58 PM
HRV-LS1's Avatar
o1ws6/tamu,
Thanks for the reply. From what I understand, your saying a 98 fuel pump/sending unit will work for the 95 GMC. That would be great. One thing, whats a up truck tank?
Old Apr 16, 2012 | 06:27 AM
gagliano7's Avatar
Just change your fuel pump on the assembly.Cheaper and easier.
Old Apr 16, 2012 | 11:47 PM
He needs the EVAP pressure sensor installed in the 98 up sender to comply with emmissions where he lives. The only way to do this is using a fuel tank and pump assembly from a 98 up truck.
Old Nov 8, 2012 | 03:54 PM
HRV-LS1's Avatar
Finally got the fuel pump assembly. Went to just check the fuel gauge and it reads 1/2 tank when the tank is empty. It reads extremely full at full ( way to the right). Is there anything I can do to solve this problem? I got the spectrum pump assembly sp461m.
Old Nov 9, 2012 | 09:20 PM
HRV-LS1's Avatar
Today tried moving the needle to empty. The gauge goes up and down but its still off. Should I try a 98 insturment cluster? If I do, will everything work on it (fuel,oil,coolant,alt,speedometer,tachometer)?
Old Nov 10, 2012 | 09:04 PM
HRV-LS1's Avatar
Where are the experts??
GXPJAY
Feb 13, 2022 08:15 AM
ss4chad
Aug 15, 2015 02:25 AM
roprisiu
Aug 9, 2015 10:47 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
