98 5.7 3500 won't start
It's a friend's truck...chugged for awhile before it died. Is there a how-to for this. I've read and heard some general stuff about replacing the pump but any advuce would bemuch appreciated. I know about the search function but direct help is always better.
I don't hear the charge with the key ON but the bob-bong-bong sound is loud and might be drowning it out. I swapped relays and checked fuses in the box under the hood. I could spray some starting fluid into the TB and see if it fires on that.
It had been "chugging along" for a long time. I think the symptoms had been gettig worse before it died.
Check pressure @ the rail. If no pressure it could be the pump or fuel filter, depending if it's getting power to the pump. This truck is probably a long bed or dually right? I'd say pull the bed if you got a couple of buddys to help. Remember to change fuel filter when changing pump.
I don't have a f.p. gauge. Is there another way to check pressure besides cracking a fitting?
BTW,he said he could hear the priming sound over the bonging noise when it was running normally.
GrooveCityZ71
Aug 31, 2015 12:05 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
