9" spec tire on a 9.5" rim?
Old Oct 30, 2008 | 07:36 PM
phasemaster1's Avatar
Default 9" spec tire on a 9.5" rim?
Has anyone ran a tire for a 9" rim on a 9.5" rim?
Old Oct 30, 2008 | 08:39 PM
Mr. Sandog's Avatar
No such thing as a tire spec'd for a 9" rim. Tires are spec'd for a range of widths. Best bet is to check the mfr's website to see what is the acceptable range.
Old Oct 30, 2008 | 08:51 PM
Yeah kind of confusing how about this.
Tire manufacture accepted range is a 9" wide rim. Has anyone put a 9" manufacture range wide tire on a 9.5" rim and had any problems.
Old Oct 30, 2008 | 09:26 PM
Stoichiometric's Avatar
I doubt you are going to have any problems. The sidewall will not sit as square with the wheel as the manufacturer wants but I bet it will work.
Old Oct 31, 2008 | 05:52 AM
SnakeOiler's Avatar
9" is not an accepted range, it is one size. As stated, there is an accepted range of width a tire can usually fit. Nothing confusing about it at all.
What size is the tire in question and the manufacturer?
Old Oct 31, 2008 | 01:39 PM
02BlueStepside's Avatar
What size tire are you trying to put on a 9.5" rim?
Old Oct 31, 2008 | 03:57 PM
This is what Im talking about http://www.nittotire.com/#index.tire.nt420s.sizes
Look at the size 255/50/18 look under approved rim it say's 7.0-(8.0)-9.0 These should be the approved rim width sizes right? So 9.0 would be a approved max 9.0".
Old Oct 31, 2008 | 05:19 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
On a 9.5 inch wide wheel, it is best to have at least a 275 wide tire. The size you mentioned could be installed on that wheel, and, for most consumers, there would probably never be any problem. But the manufacturer IS trying to protect itself from people like us, who have alot higher torque than normal, and use it regularly. With excessive torque and an improper setup, the risk of tire failure at the bead is significantly higher, and blowouts can happen if the tires are not inspected for damage regularly. I usually see these types of tire problems on chipped diesels, running the wrong setup for custom wheels and tires, but we are not immune. I hope this makes sense.
Old Oct 31, 2008 | 06:07 PM
Mr. Sandog's Avatar
That is correct. The approved range is between 7.0" and 9.0", with 9.0" being the maximum.
For the other published specs (section width, tread width, etc.), an 8.0" rim was used (this is the number in parentheses).
Old Oct 31, 2008 | 07:04 PM
Thanks everyone for helpful info.
luisalmighty09
Aug 20, 2015 11:35 PM
thewrx
Aug 12, 2015 08:28 PM
bgray
Jul 23, 2015 10:56 AM
NuckenFuts
Jul 9, 2015 08:45 AM
gcsd3742
Jul 6, 2015 05:22 PM
