73-87 C10 trucks with 5" tach
This is the way I will be going. I will be adding a shift light where the factory headlight switch is and running an Autometer Recall Tach. The headlight switch will be moved to the column.
Originally Posted by nightrunner
bette off to swap ina 400 turbo and be done with it
Mr. Obvious
if you dont do much more to your motor ok... well i dont really know what a turbo 350 will handle but i know a 400 turbo will handle almost anything stock
and it doesnt take hp to run a transmission u just have more parasitic loss in some more than others but i got what you were saying
the point i was making was the 700r4 is crap and will play out and is not worth modifying
A TH350 will work but you will need a shift kit, good quality clutches, and the biggest cooler you can use; hell this is a must for any tranny.
