6l swap wont start
Old Apr 11, 2012 | 10:38 AM
  #21
charcold-bowtie's Avatar
THe map will read somewhere in the neighborhood of 100 when the truck isnt running. Im not sure about fire, I suppose the coils are plugged in? I say that because I usually leave mine unplugged to turn it over a bit....
Old Apr 11, 2012 | 11:35 AM
  #22
southern_chevy's Avatar
well swapped crank and cam sensors with no change. sensors have power and so do coils just not firing for some reason. Everything seems good just no fire any recomondations on what to check? Coils are not getting a signal to fire
Old Apr 11, 2012 | 12:41 PM
  #23
come one someone has to have some ideas
Old Apr 11, 2012 | 12:52 PM
  #24
nonnieselman's Avatar
Hum..
check grounds
check fuses
Go ahead and do the segment swap. what OS is your current tune?
Old Apr 11, 2012 | 01:05 PM
  #25
just did the segment swap and about to go program it.
Gounds:
one on driver head on the back to fire wall
two in passanger side back of motor from wiring harness (Redid these two straight to the head)
one big cable on driver side front from block to battery
sound like I missed any? It was late amd I was tired just asking if there are anymore
Checked fuses in fuse box under hood for all ign fuses all good
Old Apr 12, 2012 | 04:32 PM
  #26
Fuses good
redid grounds
New wires
Swapped cam and cranks sensor with ones that where in truck
About 5 different programs
I am seriously about to pull the motor out of my truck been messing with it all week and still I the same boat
Old Apr 12, 2012 | 08:47 PM
  #27
Ok so swapped in new crank and cam sensor and same thing. What would be the luck of the pcm dieing on me?
Old Apr 12, 2012 | 08:58 PM
  #28
2000chevysilverado's Avatar
Might be a long shot but how about rpm signal from motor to gauge cluster my 96 wouldnt start cause of that don't know if the ls ones are wired the same but might help ya never know
Old Apr 12, 2012 | 09:19 PM
  #29
Not really sure how the yacht picks up a signal but I will look into it?
Old Apr 13, 2012 | 12:17 PM
  #30
well checked the wires for the cam and crank sensor does the below sound right?
cranks has on/off/on/off.... as you turn the motor by hand
cam has what seems half on and half off
Bumpers
Aug 4, 2024 09:44 PM
CammedZ71
Aug 2, 2015 01:44 AM
Ketis
Jul 23, 2015 12:37 PM
Deceptarado
Jul 8, 2015 05:24 PM
GreyChevy
Jul 7, 2015 08:57 PM
