6l swap wont start
How did you hydrolock the original motor? Also, you may get some better help if you post a log and tune. I have HPtuners I can't look at it but, others here might be able to help alot more if they see what you see.
I took my tune and changed cylinder volume and adjusted the be table a little bit. So all the injector info is the same or do you have to go about swapping the info another way for the new motor
What's getting me is why did 2with different map sensors read 102 kpa instead of actual pressure efi also reads 4.8 or 4.9 volt on the map that is while trying to start it. Figured even if the tune is way off it should still atleast start tho. Going to check the coils and plugs and go from there
nope just threw what I figured would need to be swapped in my tune and went with it. how hard is a segment swap?
Well tested for fire and i am getting none. So next thing what would keep it from firing the coils?
