5.3 out of 4wd into 2wd truck questions
Old Mar 27, 2016 | 11:05 PM
Shtbox's Avatar
Default 5.3 out of 4wd into 2wd truck questions
Hey guy and girls so there's a 5.3 with wiring harness out of 4wd truck on craigslist and in planning using it in my 4.3 to 5.3 swap ut the truck it's going in is 2wd so will the harness work or do I need to find a 2wd 5.3 4l60e harness??thanks in advance for any info.Motor is a 2001 and trucks a 2000 gmc sierra so there both dbc.
Old Mar 27, 2016 | 11:29 PM
FFDP's Avatar
I think the motor/trans harness is the same. Maybe the VSS is different because the 4x4 has a transfer case??
Old Mar 27, 2016 | 11:47 PM
Shtbox's Avatar
Ok so when I get my ecm flashed to my vin and 5.3 data my tuner can make those adjustments?I was just worried that the plugs on the trans would be wired different
Old Mar 28, 2016 | 01:06 AM
1FastBrick's Avatar
Custm2500's Rude Friend
A 4x4 transmission has a different length output shaft. It's shorter. You would have to disassemble the whole trans to change it out. Your better of getting a 2wd transmission.
The wiring harness would have additional plugs for the front differential and depending on which transfercase may also have additional plugs for the actuator and what not. It will still work in a 2wd application though. It would just have extra plugs that are not used.
Old Mar 28, 2016 | 04:15 PM
Shtbox's Avatar
Well that's good news thanks 1FastBrick I'm gonna use the 4l60e in the v6 truck and see how long it lasts I heard the trans was the same so well see different torque converter tho right?
Old Mar 28, 2016 | 04:31 PM
2002_Z28_Six_Speed's Avatar
The TC for the lower power application will probably handle it but stall slightly higher. TCC might not be as resilient.
ls88truck
Feb 19, 2016 10:30 AM
Jeremy Cookie Cook
Feb 17, 2016 08:40 PM
Shanewabindato
Feb 16, 2016 12:17 PM
Slow91z
20
Feb 15, 2016 03:51 PM
fillpot
Feb 1, 2016 10:04 PM
