4l80e swap dipstick tube
Old Jan 23, 2018 | 02:33 PM
ILuvJDM's Avatar
Originally Posted by Ken in AZ
Yeah - I'll second the impossible part. I did the same thing on my 4L80e swap - ended up buying a Lokar flexible dipstick - works great, only hurt the wallet to the tune of about $100. Yeah I'm a Lazy SOB haha
$100 is pocket change in comparison to pulling the trans back down
Old Jan 23, 2018 | 02:55 PM
Drspencer's Avatar
5 Year Member
That was an option but it wouldn't arrive until today so I told the guy last Friday I'll give him another $100 to do it by Sunday. I'm still under $1000 for the whole swap with install after I sold the 60E so whatever. Now I just need to swap this loose *** converter....ha
Old Jan 29, 2019 | 08:57 AM
BSANT11's Avatar
Hey whats up guys i have a question. i just did a 4l80e swap on my truck(2011 silverado rcsb) and im having issues with the dipstick. i bought a dipstick of an 05 2500hd silverado with the 80e and tried installing it on mine and its being a bitch and wont go in. tried bending and doing all kinds of things and nothing. if anyone has any info that be cool, before i buy one of those flexible dipsticks but there too short..... thanks
Old Jan 29, 2019 | 10:36 AM
darkirish63's Avatar
What tube are you using?
Old Jan 29, 2019 | 10:38 AM
BSANT11's Avatar
Stock tube out of an 05 2500hd with an 80e
Old Jan 29, 2019 | 11:53 AM
If the tube is torqued to the side a tad on the mounting bolt on the block, it will bind - mine did when I did my swap.
Old Jan 29, 2019 | 04:43 PM
madmann26's Avatar
If you already put the trans in the hole and bolted it to the block, you’re fucked.
Old Jan 30, 2019 | 02:40 PM
Yup...
Old Feb 1, 2019 | 07:41 AM
MikeGyver's Avatar
I re-reinstalled my trans when I first time forgot to put in the dipstick tube after researching a flexible replacement. I read that the flexible tubes have a too small inside diameter, causing it to be super slow adding fluid. I think that the stock tube takes too long to add fluid and I didn't want less flow than that.
Old Feb 1, 2019 | 07:53 AM
6.0 pickup's Avatar
5 Year Member
Disconnect crossmember at tranny , pull driveshaft, jack tail of tranny up . This gives you more room between motor and firewall. Still PIA but work on my 99 RCSB Silverado
