4l80e swap dipstick tube
Need the 4l80e dipstick tube . Does anyone know the exact part number to order . Doesn't matter if it's a flexible or regular just trying to make sure I order the right one thanks
Has anyone tried installing this AFTER the trans was installed? I forgot about it and then the trans was installed and now can't get the damned thing in... Any hints or tricks? The guy installing is a GM trans tech. Saw one where a guy just
"Stab it to the right a bit of where it is supposed to end up and rotate counter-clockwise as it goes down"
But no luck. Any other suggestions besides removing and installing the trans with the tube installed?
Yeah, guy ended up just pulling the trans again. If you undo the crossmember and try to point it down, the cylinder heads or something hits the firewall preventing it from going down any further before you have enough space for the dipstick to twist.
SO, in my experience, on the GMT900 trucks (maybe just my Avalanche), it appears to be impossible to install the trans dipstick while the transmission is installed in the vehicle.
Yeah - I'll second the impossible part. I did the same thing on my 4L80e swap - ended up buying a Lokar flexible dipstick - works great, only hurt the wallet to the tune of about $100. Yeah I'm a Lazy SOB haha
