4l80e swap dipstick tube
Old 03-25-2017, 11:03 PM
Luis3701's Avatar
Default 4l80e swap dipstick tube
Need the 4l80e dipstick tube . Does anyone know the exact part number to order . Doesn't matter if it's a flexible or regular just trying to make sure I order the right one thanks
Old 03-26-2017, 08:21 AM
ILuvJDM's Avatar
This is what I just ordered, hopefully it's the correct one, I got the part number from rockauto - 15832205
Old 03-31-2017, 11:57 AM
darkirish63's Avatar
That's the one I used for my swap as well.
Old 01-18-2018, 08:27 AM
Drspencer's Avatar
Has anyone tried installing this AFTER the trans was installed? I forgot about it and then the trans was installed and now can't get the damned thing in... Any hints or tricks? The guy installing is a GM trans tech. Saw one where a guy just
"Stab it to the right a bit of where it is supposed to end up and rotate counter-clockwise as it goes down"
But no luck. Any other suggestions besides removing and installing the trans with the tube installed?
Old 01-18-2018, 12:43 PM
Custm2500's Rude Friend
1FastBrick's Avatar
If you remove the crossmember you should be able to move the trans around and get the tube in.
Old 01-18-2018, 09:41 PM
shupe's Avatar
Id second this.
Old 01-19-2018, 06:21 AM
Drspencer's Avatar
Yeah the crossmember has been disconnected. It’s the custom unit that one guy makes. Can’t remember his username. The trans is as loose as it can’t get without pulling this. It’s on a lift.
Old 01-20-2018, 09:39 PM
madmann26's Avatar
It's damn near impossible. The first time I pulled my 60e out, when I put it back I forgot to drop it in before bolting the trans up.
Old 01-22-2018, 07:47 AM
Drspencer's Avatar
Yeah, guy ended up just pulling the trans again. If you undo the crossmember and try to point it down, the cylinder heads or something hits the firewall preventing it from going down any further before you have enough space for the dipstick to twist.
SO, in my experience, on the GMT900 trucks (maybe just my Avalanche), it appears to be impossible to install the trans dipstick while the transmission is installed in the vehicle.
Old 01-23-2018, 02:27 PM
Ken in AZ's Avatar
Yeah - I'll second the impossible part. I did the same thing on my 4L80e swap - ended up buying a Lokar flexible dipstick - works great, only hurt the wallet to the tune of about $100. Yeah I'm a Lazy SOB haha
