4 headlight mod
Old Mar 12, 2006 | 01:03 AM
ltn's Avatar
ltn
Default 4 headlight mod
Hey i know how to do the mod but i was just wondering if i could get all four sets of lights to come one at once. if so could anyone just tell me which ones i have to connect. on yeah i also want this to happen when the high beams are turned on. thanks
Old Mar 12, 2006 | 02:24 AM
04BlackSilverado's Avatar
I wrote up the mod on how to do it, but what year is your truck? The mod I wrote is for the 03+ trucks(not sure if it works on the 05+, but assuming it will). Do a search and you will find the mod for the 99-02 and the one for the 03+
Good luck
Old Mar 12, 2006 | 03:57 PM
8MC's Avatar
8MC
I did the the mod that 04BlackSilverado wrote up on both my 03 and 06. Real easy and cost under 2 bucks.
Old Mar 12, 2006 | 09:35 PM
ltn's Avatar
ltn
ok cool but u guys think that the 99-02 trucks are different? because i have a 02
Old Mar 12, 2006 | 10:22 PM
The 99-? (maybe 02) have a negative high/ low beam switch. I am about to do a 4 headlight conversion on my truck, when I get around to it.
My current idea uses 3 relays and 12 gauge wire for the headlight power feed and 16 gauge wire for the signal wire for the relays.
Relays
1 - low beam
1 - high beam
1 - turns the low beam on when the high beams are on
There is also a method of using a diode but I am not too convinced about this method
This is oem wire color;
orange - +12V
yellow - low beam, this wire goes to the ground through the headlight switch
purple - high beam, this wire goes to the ground through the headlight switch
Old Mar 13, 2006 | 05:19 AM
COLDZ71's Avatar
Relays
1 - low beam
1 - high beam
orange - +12V
All you have to do to get 4-hi on a 99-02 is ground one wire under the engine compartment fuse panel.
madmann26
Apr 29, 2020 09:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
bisqikss
Sep 27, 2015 09:40 PM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
