4.8's dont suck
single digit dreamer
that is a nx filling station. i dont have to heat or cool bottles anymore. just hook it up and turn on the pump.
it has been working great but i am only geting about 45lb's out of a 65lb bottle. i am 99% sure it has been because i have been using the upright bottles with a syphon tube in them and the tube doens't go all the way to the bottom. i hope to get all 65lb's out easily with the inverted bottle and no syphon tube.
on my last upright bottle it stoped pumping about 45lb's. i unhooked the hose and just let the bottle drain itself. there was no liquid nitrous coming out, it was mostly air. after a few minutes you could see the bottom 10" of the bottle frosting up. it was where the liquid was and was boiling off and freezing up the bottle. that tells me the syphon tube was 10" from the bottom of the bottle.
Originally Posted by Scream
I thought for a second that you had a nitrous-fed 4.8 powering your air compressor.
So Parish, how could i get ahold of a filling station? Up here the only place to get N2O is the track, and to fill a 10# bottle its more than $60
I could make some money off the other Military guys, and local ricers.
Originally Posted by Snake Eater
LMAO!
being able to keep my bottles toped off is a huge benifit. i hated going in for fills and then never knowing how much i used and then runing out 1/2 way thru the night.
you will want to call some gas companys and see how much they sell the big bottles for. dont count on any more than 50lbs out of a 65lb bottle and see if it is worth your time.
