4.8 and/or 5.3 going away?
Old May 13, 2007 | 08:42 PM
  #21
niugnep's Avatar
Originally Posted by Wide Open
The only way this could happen is if Toyota and Nissan keep up the pressure. Toyota has the 5.7 and 6 speed available in all their trucks but GM continues to restict the availability of the 6.0 and lets not even talk about the 6L80E being available anytime soon.
Agreed, not sure why GM does that. I mean yeah currently the trucks are better IMHO but why not offer whatever you can and crush the competion? As it is they will get a foothold and keep on strokin...Toyota has nothing to lose and billions to spend, GM got handed some lucky breaks (tundra only getting 4 star safety rating etc) but they aren't capitalizing on it...
I debated waiting a bit for the 6 speed, good thing I didn't. Might trade up later or drop one in myself, need you to sort that stuff out first!!
Old May 14, 2007 | 10:52 AM
  #22
Originally Posted by Quik
heads and intake are totally different, 6.2 is a DOD motor as well and depending on which 6.2 you have it could have VTT. along with placement of sensors and some other wireing...biggest is the head and intake
Yeah I did notice the head diffrence right off the bat. PLus, SLP is singing the praises for these 6.2 L92 heads. So they must flow good. But they are the exact same part # as the 2007 Classic 6.0 heads. So there can't be a bunch of diffrences.
I noticed the high rise intake also....and was wondering what diffence it would make on a 5.3?
Old May 14, 2007 | 11:08 AM
  #23
nighthawk08's Avatar
tons of differences...check on ls1tech for L92 info.
Old May 14, 2007 | 01:22 PM
  #24
I did check on that....also I own the issue of GM High Tech on this same subject. Those are SLP Heads...not OEM 6.2 heads....SLP has had them worked.
But what I'm saying is....here....read below.
12582714 part# for 6.2 H.O. heads....same part # for the 6.0 in the 2500HD
...and this is on a 2007 new Tahoe and 2007 Classic 2500HD.
So I have to ask the diffrence between teh 6.0 and the 6.2. Know what I'm saying?
Old May 14, 2007 | 01:24 PM
  #25
there's a glitch in your system
Old May 14, 2007 | 01:34 PM
  #26
CHEVRACER83's Avatar
There Are 2 Designes For 6.2 L Engine...with Afm And Without Active Fuel Management
Both Heads Are Showing The Same Number... 6.0 Is Also Showing It... Torque Wrench Is Correct. These Are For The "stock" Heads Though 12582714
In The Gm Performance Catalog... They Are Showing L76 And L92 High Flow Heads Are Same Design/pn... 12582713
Old May 14, 2007 | 01:36 PM
  #27
GMCtrk's Avatar
The L76 6.0 has the L92 heads on it, that's the reason for the power increase.
Old May 14, 2007 | 01:39 PM
  #28
Yeah The Lq9 Old Style 6.0 Has Totally Different Heads...
12562319
Old May 14, 2007 | 01:42 PM
  #29
Wide Open's Avatar
So does this mean the 6.0 (I assume the VortecMax) has the L92 heads and intake?
Old May 14, 2007 | 02:02 PM
  #30
No The 07 With The Engine L76 6.0 Will Have The L92 Heads If Its Not That 6.0 The No Its Got The Old Style Heads
