2006 Silverado. My a/c fan wont stop blowing,even with key off. What part is bad?
Old Feb 5, 2013 | 11:13 PM
Suburbazine's Avatar
Again, stuck on with key off is going to be a resistor. A bad control board generally can't send voltage to the resistor with the key off. A bad resistor, however, can short out and send battery power to the blower at all times.
If you really want to find out, pull the resistor connector and probe the small wires with a voltmeter to ground. If you've got juice on a small wire (small purple I think) then you may have a bad head unit.
Old Feb 6, 2013 | 07:06 AM
NO F-BDY BS's Avatar
Originally Posted by Suburbazine
Again, stuck on with key off is going to be a resistor. A bad control board generally can't send voltage to the resistor with the key off. A bad resistor, however, can short out and send battery power to the bloweri at all times.
Can a bad resistor cause the control unit to act quirky like I listed above in regards to the fan settings?
Old Feb 6, 2013 | 12:50 PM
Yes and no. Yes, it will make the blower speeds go stupid. No, it probably won't affect other functions unless the 2006 has a stupid bidirectional communicating resistor like some new model BMWs. (I'm fairly certain is doesn't)
Do pull it and check the wire voltages like I posted earlier, will assist in diagnosing.
Old Feb 6, 2013 | 01:56 PM
Cool,thanks.
Edit: a guy I work with just traded his truck,which was an 06' with the AUTO climate ac. Said his was doing the same thing,he took it to gm and they replaced the resistor.
Rockauto.com has the unit for $50,so I may just roll the dice on that.
mr03silverado
Jun 26, 2016 06:05 AM
creekrat
Aug 2, 2015 01:27 AM
atxlt
Jul 20, 2015 11:06 PM
rojeho
Jul 12, 2015 06:10 PM
