2006 silverado 1500 and ly6 engine/4l80e trans
Old Apr 26, 2016 | 06:05 PM
  #51
Wolftrk99's Avatar
No problem.... Been there!!!
Old Apr 26, 2016 | 07:38 PM
  #52
Thoagland's Avatar
so got the vats light off....
it still cranks for about 3 seconds then the starter signal shuts off
Old Apr 26, 2016 | 08:34 PM
  #53
Wolftrk99's Avatar
Disconnevt the battery for about 15 seconds and try again
Old Apr 26, 2016 | 08:38 PM
  #54
Thoagland's Avatar
gave that a shot with no luck
Old Apr 26, 2016 | 08:52 PM
  #55
Wolftrk99's Avatar
Do you have a way to pull codes from all the modukes bcm, pcm, etc, etc....
Old Apr 26, 2016 | 08:53 PM
  #56
Thoagland's Avatar
Shouldn't the vcm scanner be able to do that?
Old Apr 26, 2016 | 08:55 PM
  #57
Wolftrk99's Avatar
Honestly havent played with it in that capacity.... Not sure...
Old Apr 26, 2016 | 08:56 PM
  #58
Thoagland's Avatar
There's a diagnostic section where you can pull codes...which it is not throwing any codes at the moment.
Old Apr 26, 2016 | 09:11 PM
  #59
FFDP's Avatar
You didn't re-write the old tune into this computer did you??
You licenced this file and made the similar changes besides the ETC tables with your 4L80e swap and wrote it in right?
Old Apr 26, 2016 | 09:13 PM
  #60
Thoagland's Avatar
No I did not. The tune was downloaded from my email, renamed it so I could easily distinguish it then uploaded it right away.
The other time when the etc table was changed, it gave a code p0606. I am getting no codes right now.
