2002 1500 5.3 with 150k miles
Old Dec 12, 2011 | 10:32 PM
6789olds's Avatar
Default 2002 1500 5.3 with 150k miles
a co worker of mine has a 02 with 5.3 and 150k and its has a rough idle for about 5 seconds after the inital start . then it idles smooth ? any ideas of what it might be . he put bosh plugs in it and i told him to run the tr5 and that didnt work . no check engine light . i recomended cleaning the mass air sensor.
Old Dec 12, 2011 | 11:13 PM
Mangled03gmc's Avatar
Baltimore Whore
Clean MAF sensor, clean the TB, sea foam it.. Put the stock NGK plugs back in it.. Should do the trick
Old Dec 12, 2011 | 11:21 PM
454SuperSport's Avatar
fuel pressure regulator on driver side fuel rail, pull the vac line off while the truck is running and watch the nipple on the regulator for a few minutes. I'd be willing to bet you'll see fuel start to seep out, and a new regulator should cure it
Old Dec 12, 2011 | 11:38 PM
6789olds's Avatar
thanks we will give it a look
Old Dec 13, 2011 | 11:40 AM
letsrun97z's Avatar
My truck does the same only when cold but for about a minute. When it's below 40 I also get a random cyl missfire won't do it at all during the summer
Old Dec 19, 2011 | 02:27 PM
6789olds's Avatar
Thanks 454 it was the fuel pressure. Regulater runs great now.
Old Dec 20, 2011 | 10:21 PM
Glad to help
Choda
Jan 22, 2026 02:03 PM
ferrellrooster
Mar 6, 2025 03:22 PM
SLOPONY
20
Oct 18, 2016 06:05 AM
bsgiffor
Jul 19, 2015 11:14 AM
My72olds
Jul 10, 2015 11:26 AM
