2001 4x4 Tahoe..Changing Oil Pan Gasket
Old 07-31-2012, 08:49 PM
nickleahy23's Avatar
did it today..pretty simple..4 bolts on the diff and a xmember under the pan..still ******* leaks..i have no idea what to do now..have done oil pan gasket, valley pan gasket, valve cover gaskets, rear main etc..last thing i can think of is oil pressure sender but it doesnt seem to be leaking
Old 08-01-2012, 09:32 PM
11 Second Club
brent1976's Avatar
I went through the same thing. Mine ended up being a crack in the rear drivers side of the oil pan itself.
I didn't find the crack until I installed the oil turbo drain, and took the pan out to drill/tap for it.
Old 08-20-2012, 09:30 PM
well my leak is even worse now..im down a quart in 3 weeks..just pisses me off..
problem i can see, i stripped the rear 2 bolts somehow..the 2 tiny ones that go all the way through the pan into the rear cover..i had a torque wrench and had it at 177 in lbs or whatever it needed..stripped both of them but they are still "tight" and there are like 4 other bolts around those, plus the 2 that go through the bellhousing, so i cant see that being a problem..time to find a another 6.0 and sell this one for a few bucks..it would be so much easier to swap another motor then try to find this leak lol
Old 05-09-2018, 08:45 PM
Registered User
Dgallardo's Avatar
It has to be the rear main seal
Old 05-10-2018, 08:14 AM
ILuvJDM's Avatar
Hopefully he fixed that within the 6 years since this thread was made.
Old 05-10-2018, 10:02 AM
2002_Z28_Six_Speed's Avatar
did you follow the toque sequence and spec when did the oil pan?
Old 05-12-2018, 04:37 PM
Mark Johnson's Avatar
Originally Posted by brent1976
I took the motor mounts loose and picked up the engine with a hoist. It made plenty of room.
Listen to this man..............
spent21
08-19-2015 02:37 PM
Ls3silverado
07-31-2015 04:22 PM
05SilveradoSS
07-29-2015 08:34 PM
jmarkway
07-18-2015 09:23 PM
Quick Reply: 2001 4x4 Tahoe..Changing Oil Pan Gasket
