2000 Chevy Silverado 5.3 random misfires
Old May 23, 2025 | 09:48 AM
bennettmcm's Avatar
Default 2000 Chevy Silverado 5.3 random misfires
I have a 2000 Silverado with 5.3 nv3500. Been chasing this random miss fire code for months. Did the following. Smoke test for vaccuum leaks, all new plugs and wires, replaced mass air flow sensor, replaced fuel pressure regulator. I checked fuel pressure and it is reading low like 40-45psi . I’m thinking that is probably an issue. So would I need to replace the fuel pump? Don’t want to keep throwing parts at it if it’s not going to fix it. Would appreciate anyone’s feed back and help thank you !
Old May 23, 2025 | 09:58 AM
strutaeng's Avatar
5 Year Member
That pressure does seem low for a non-flex-fuel engine. That's at idle? Can you stick your fuel pressure guage to your windshield with duct tape (may need a longer hose) and go for a drive. Do a few WOT accelerations and check fuel pressures. See if you can correlate the misfire with lower fuel pressure readings.
Old May 23, 2025 | 10:04 AM
bennettmcm's Avatar
I got a new fuel pressure gauge and just checked it fuel pressure is sitting right at 50 psi at idle
Old Jul 27, 2025 | 10:03 PM
RedHot04's Avatar
Had the same issue. Replaced fuel injectors and no more P0300! Only had 2 bad ones but opted to just replace the set.
Old Aug 22, 2025 | 12:39 PM
Fullpower's Avatar
There's a guy that will clean, and flow test your injectors.
The OEM Delphi is good stuff. I'd rather spend money on GOOD parts than buy Xhinese sheeit that's swamped the market.
Derr Injection.
502
381
4678
Third Gear
Dec 9, 2011 06:54 PM
20chevy01
19
Jan 27, 2011 11:41 PM
