160T-Stat and Tune????
Here's what happened: I go out to the Silvy to run to the store real quick and there is that orange colored fluid under the passenger side just next to the front tire. Upon futher investigation I found the t-stat leaking. I tried to tighten it but it did not help. The o-ring ended being the problem, is was cracked and partly comming out. I have a 160 power stat waiting to install, but I was waiting to do it when I got a tune. I'm not going out and buying a stock t-stat when I have this one, so I figured whatever and installed it.
Will there be any issues running this 160 for a while till I get my tune done?
Originally Posted by BBLS1
shouldn't have no problem. I installed my in before a tune. The only thing is that it will steal run at the same temp(some times),
So far it runs significatly lower temps. If you were looking at the gauge it reads 160 then three small lines then a large line again. It consitantly sits at that large line, I'm guessing 180ish. With a/c on or with a/c off, in traffic, or just sitting there ideling. I have seen no fluctuation at all which is good.
I was mainly concerned with the truck thinking it wasn't up to normal temps yet and the pcm adjusting air and fuel or such?
Might not have a problem where you live but up north here mine kept triping a code for coolant temp (spring& fall) which screwed me at inspection time. When I got my retune at Ed Wright they took care of it.
Originally Posted by dinnut
i put a 160 thermostat in mine and it still runs the exact same place it did before. stillllllllll trying to get ahold of charlier(wheatley) but he NEVER answers the phone apparently
Man has ran up to were it used to from factory once or twice since the install, but I left the truck sitting and ideling for about an hour to do this. I still have the clutch fan so efans would really help out.
